Maybe you can help me, I would be very grateful.
I purchased the Directadmin control panel license from https://www.directadmin.com/ and installed it on my server in accordance with the instructions provided at http://www.directadmin.com/lan.php. Lan however, the server is running through a modem. I tested the ports of the modem, skip all the necessary. Everything succeeded well. The local network is running smoothly, but the external network is not working The directadmin panel external network is working, but the web site http://mano_domain.eu does not work.
Server OS Centos 6.9 My Apache Error Log:
"[Sat Dec 02 12:46:01.555396 2017] [mpm_event:notice] [pid 3038:tid 140139739068352] AH00491: caught SIGTERM, shutting down
[Sat Dec 02 12:46:01.721180 2017] [ssl:warn] [pid 4658:tid 139941477705664] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Dec 02 12:46:01.721357 2017] [suexec:notice] [pid 4658:tid 139941477705664] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Dec 02 12:46:01.738356 2017] [ssl:warn] [pid 4659:tid 139941477705664] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Dec 02 12:46:01.738505 2017] [lbmethod_heartbeat:notice] [pid 4659:tid 139941477705664] AH02282: No slotmem from mod_heartmonitor
[Sat Dec 02 12:46:01.740032 2017] [mpm_event:notice] [pid 4659:tid 139941477705664] AH00489: Apache/2.4.29 (Unix) OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Dec 02 12:46:01.740100 2017] [core:notice] [pid 4659:tid 139941477705664] AH00094: Command line: '/usr/sbin/httpd' "
