problem maillinglist, after restore
snaaps
Netherlands
last week our servers has been crashed and whe have restore it with the admin backups.
After the restore the maillinglists not work anymore.
The mainlog says:
PHP:
2008-10-10 16:04:04 1KoIb6-00008L-7g <= [email protected] H=ccc00.ccchosting.nl (ccc00.serverparkcapelle.nl) [84.243.245.34] P=esmtps X=TLSv1:AES256-SHA:256 S=2851 id=071501c92ae1$0cc7f910$2657eb30$@nl T="test 2" from <[email protected]> for [email protected]
2008-10-10 16:04:04 1KoIb6-00008L-7g ** |/etc/virtual/majordomo/wrapper resend -C /etc/virtual/proximitas.nl/majordomo/majordomo.cf -l ccc -h proximitas.nl -f owner-ccc [email protected] <[email protected]> F=<[email protected]> R=majordomo_aliases T=majordomo_pipe: Child process of majordomo_pipe transport returned 127 (could mean unable to exec or command does not exist) from command: /etc/virtual/majordomo/wrapper
2008-10-10 16:04:04 1KoIb6-00008Q-8l <= <> R=1KoIb6-00008L-7g U=mail P=local S=4269 T="Mail delivery failed: returning message to sender" from <> for [email protected]
2008-10-10 16:04:04 1KoIb6-00008L-7g Completed
2008-10-10 16:04:04 1KoIb6-00008Q-8l => [email protected] F=<> R=lookuphost T=remote_smtp S=4406 H=mail.ccchosting.nl [84.243.245.37] X=TLSv1:AES256-SHA:256 C="250 OK id=1KoIbD-0004vP-5u"
2008-10-10 16:04:04 1KoIb6-00008Q-8l Completed
2008-10-10 16:04:09 H=ccc00.ccchosting.nl (ccc00.serverparkcapelle.nl) [84.243.245.34] F=<[email protected]> rejected RCPT <[email protected]>: Unrouteable address
2008-10-10 16:04:09 H=ccc00.ccchosting.nl (ccc00.serverparkcapelle.nl) [84.243.245.34] incomplete transaction (QUIT) from <[email protected]>
somebody here can help me with this to restore this?
I ran into the same issue, same conditions.
Tell me, what's the size of the "wrapper" file you'll find in /etc/virtual/majordomo ? (cd /etc/virtual/majordomo then ls -al. no pun intended)
After having removed the /etc/virtual/majordomo directory and having run the DA majordomo install script I found a "wrapper" file with size 136 but troubles persisted.
Replaced it with a "wrapper" file with size 7670 coming from an other (older) DA install and everything seems to be up and running again.
Don't forget to check if ownership, SUI and rights are correct in case you replace the file (owner root:daemon, rights 4755. again no pun intended)
Hope this is of help.
Edit : the message you posted could also point to a misconfigured destination email address or the fact you try to send a test post to the wrong address. hence, if everything within it is 100% valid and correct my above reply could help.
