Hello Again
IF you Installing suphp from this way :
./build set php5_cgi yes
./build set php5_cli no
./build all d
./build rewrite_confs
Now after suphp is installed on the server. You will need to fix phpMyAdmin, Roundcube and squirrelmail
./build roundcube
./build squirrelmail
./build phpmyadmin
No you can fix the permissions of all the files and folders of the users:
for i in `/bin/ls /usr/local/directadmin/data/users/` ; do chown -R $i.$i /home/$i/domains/* ; echo $i ;done
for i in `/bin/ls /usr/local/directadmin/data/users/` ; do find /home/$i/domains/ -type f -exec chmod 644 {} \; ; echo $i ;done
for i in `/bin/ls /usr/local/directadmin/data/users/` ; do find /home/$i/domains/ -type d -exec chmod 755 {} \; ; echo $i ;done
Regards , Hossein
