Problem starting apache (Custombuild)
rizwan65
Hi
I have a VPS with Custombuild which was running alright for the last few months
Today I got a message that port 80 is down
I am trying to start my apache but getting the error
[root@da admin]# service httpd restart
Stopping httpd: [FAILED]
Starting httpd: Syntax error on line 30 of /etc/httpd/conf/httpd.conf:
Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
I have checked the httpd error_log and found in tail -f
[Mon Jan 26 13:18:47 2009] [error] [client 58.181.107.178] Invalid method in request 1
[Mon Jan 26 13:18:47 2009] [error] [client 58.181.107.178] File does not exist: /var/www/html/501.shtml
[Mon Jan 26 14:23:36 2009] [warn] (101)Network is unreachable: connect to listener on [::]:443
[Mon Jan 26 14:23:37 2009] [warn] (101)Network is unreachable: connect to listener on [::]:443
[Mon Jan 26 14:23:37 2009] [notice] caught SIGTERM, shutting down
I have also tried rebooting the VPS but same problem
I didn't altered anything in any conf file
Any suggestions
Regards
Rizwan
Have you tried looking at line 30 of /etc/httpd/conf/httpd.conf?
Line:29 <Limit GET POST OPTIONS PROPFIND>
Line:30 Order allow,deny
Line:31 Allow from all
Line:32 </Limit>
same issue
I am having the same exact issue on the same exact line of code. Mine is a new install. Did you resolve this?
resolved
FYI the support guys think that this is some kind of yum update that is breaking Apache. I have not gotten a clear answer from them on it. However this is what fixed my server.
Type:
./build rewrite_confs
Also, to ensure that you've got all of the correct software, I'd recommend a full recompile of the apache, php, dovecot services:
./build all d
Type:
./build all d
To recompile correctly (for this case)
./build apache
./build php n
dovecot has nothing to do with Apache, dovecot is for email.
After running:
./build all d​
I got the following:
Restarting apache.
Stopping httpd: [ OK ]
Remaining processes: 1
Starting httpd: [ OK ]
[Sat May 22 22:48:04 2010] [warn] (2)No such file or directory: Failed to enable the 'httpready' Accept Filter
[Sat May 22 22:48:04 2010] [warn] (2)No such file or directory: Failed to enable the 'dataready' Accept Filter​
So, I did:
./build apache
./build php n​
Things appear to be working, but I have not done a complete test.
Ideas?
Thanks smtalk.
Question. My /boot/loader.conf has not been modified, why would this problem exist as new?
#cat loader.conf
kern.hz="200"
Could there be another file that would have included
accf_http_load="YES"
accf_data_load="YES"
Or since I've not need to retart apache in the past, is it more likely that it had always been a confuration problem?
CustomBuild uses improved Apache configuration and it requires httpready and dataready accept filters. I guess you had CustomApache installed in the past.
