Problem to connect to directadmin from 3G connexion
pppplus
I've a small problem. I can't connect to directadmin from my phone.
Port 2222 is open.
The problem (I suppose) is that my IP connexion from my phone change everytime.
And I think directadmin verify IP
Is there a feature to desactivate this protection ?
I search, but not easy to find something with word like IP, 3G ...
You should better try 3rd party proxy server then or even a VPN if it's possible to use in your situation with IP that changes.
By the way does it change on every request or only if you disconnect and connect again?
Thanks for your replies.
zEitEr : IP change every second (sometimes more, sometimes less)
support : perfect, I would modify it only when I need to connect to directadmin.
