Problem to websites associated to mi vps ip
Hosteado
English:
Hi, I installed DirectAdmin on my server.
The problem is to have one or more accounts, all domains associated with the IP of the server page it appears 1 that was created with the DirectAdmin instead of "Apache is running. "
Here's an example: http://46.4.175.210/
Spanish:
Hola, he instalado el directadmin en mi servidor.
El problema esta al tener uno o mas cuentas, todos los dominios asociados a la IP del servidor le aparece la pagina 1º que se creo con el directadmin en vez del "Apache is running".
Aquí un ejemplo: http://46.4.175.210/
Check to see the IP# assigned to the user/domain name.
Check to see the DNS you're publishing for the domain name.
They must match.
If they do match then restart apache and wait at least one minute before testing again.
If they don't match, then change one or the other as required so they match and are properly hosted. Then restart apache, and then wait as long as a day before testing again.
If they still don't match, then someone will need to check your server.
