Problem Tunning Primer MySQL
ruderforerver
My problem check my.cnf
- INITIAL LOGIN ATTEMPT FAILED -
Testing for stored webmin passwords:
None Found
Could not auto detect login info!
Found Sockets: /var/lib/mysql/mysql.sock
Using: /var/lib/mysql/mysql.sock
Would you like to provide a different socket?: [y/N] n
Do you have your login handy ? [y/N] : test
Please create a valid login to MySQL
Or, set correct values for 'user=' and 'password=' in ~/.my.cnf
Would you like me to create a ~/.my.cnf file for you? [y/N] : n
What should I choose in socket number: Would you like to provide a different socket?: [y/N] y ?
check where the sock is, use find / -name mysql.sock
Also, provide a valid user, like da_admin (the password is stored in /usr/local/directadmin/conf/mysql.conf
Regards
