On Debian 5 32bit if you have set mysql_inst=yes in the options file of custombuild instead of downloading mysql-5.0.90-linux-i686.tar.gz it downloads mysql-5.0.90-linux-x86_64.tar.gz causing the mysql server to stop working.
If you have the same problem, to restart mysql do the following:
cd /usr/local
rm mysql (to remove the symbolic link)
Check your previous version doing ls -la. In our case it was mysql-5.0.89-linux-i686, so:
cd /usr/local
ln -s /usr/local/mysql-5.0.89-linux-i686 /usr/local/mysql
rm -r -f mysql-5.0.90-linux-x86_64
rm mysql-5.0.90-linux-x86_64.tar.gz
Then change the settings of custombuild
pico option*
mysql_inst=no
and CTRL+O to save CTRL+x to exit
./build update_data
./build update_versions
./build php n
and finally restart.
Anyway I don't understand why it downloads the wrong file. We have 12 servers and all had the same problem. If you have any clues please let me know.
cd /usr/local
cd /usr/local
pico option*
mysql_inst=no
./build update_data
./build php n
