https://www.directadmin.com/features.php?id=1754
Are you sure the server timezone is correct?
You could try to edit twostep_auth_discrepancy=1 to 4 for example.
Could it be a firewall that blocks the sync (port)?
I thought port 123
I activate the 2FA in admin login, but there is problem. after few days it's out of sync (I think clock problem) and it return to work only after reboot.
someone knoe how to solve it?
thank you
