Problem with build roundcube
Omid
Hi , after ./build roundcube I'm getting:
[root@serv custombuild]# ./build roundcube
cp: `/var/www/html/roundcube/logs' and `/var/www/html/roundcubemail-0.9.5/logs' are the same file
cp: `/var/www/html/roundcube/temp' and `/var/www/html/roundcubemail-0.9.5/temp' are the same file
Editing roundcube configuration...
Roundcube 0.9.5 has been installed successfully.
WARNING: Missing config options:
(These config options should be present in the current configuration)
- 'des_key'
Do you want me to fix your local configuration? (y/N)
y
. backing up the current config files...
. writing /var/www/html/roundcubemail-0.9.5/config/main.inc.php...
. writing /var/www/html/roundcubemail-0.9.5/config/main.db.php...
Done.
Your configuration files are now up-to-date!
But you still need to add the following missing options:
- 'des_key'
Executing database schema update.
ERROR: Error connecting to database: SQLSTATE[28000] [1045] Access denied for user 'da_roundcube'@'localhost' (using password: YES)<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><head>
<title>Roundcube Webmail :: ERROR</title>
<link rel="stylesheet" type="text/css" href="skins/larry/common.css" />
</head>
<body>
<table border="0" cellsapcing="0" cellpadding="0" width="100%" height="80%"><tr><td align="center">
<div>
<h3 class="error-title">SERVICE CURRENTLY NOT AVAILABLE!</h3>
<p class="error-text">Error No. [500]</p>
</div>
</td></tr></table>
</body>
</html>
what should i do ? , pls help :(
