I changed my configure.php to use an external version of GD (not the internal version compiled into PHP), my configure.php looks like this:
pay attention to this line "--with-gd=/usr/local \" as the default would be "--with-gd \", the default will use the internal version of GD, as I require FreeType support and have tried everything to get the internal version compiled with TrueType support I've finally decided to use an external version.
Now if I use the internal version everything compiles fine but when I use the external version I get the following error:
How can I solve this problem?
#!/bin/sh
./configure \
--with-apxs \
--with-curl \
--with-curl-dir=/usr/local/lib \
--with-gd-dir=/usr/local \
--with-freetype-dir=/usr/local \
--with-gettext \
--with-jpeg-dir=/usr/local/lib \
--with-kerberos \
--with-mcrypt \
--with-mhash \
--with-mysql=/usr \
--with-pear \
--with-png-dir=/usr/local/lib \
--with-xml \
--with-zlib \
--with-zlib-dir=/usr/local/lib \
--with-zip \
--with-openssl \
--with-libfreetype \
--enable-bcmath \
--enable-calendar \
--enable-ftp \
--enable-magic-quotes \
--enable-sockets \
--enable-track-vars
Trying to make php...
/bin/sh /usr/local/directadmin/customapache/php-4.3.10/libtool --silent --preserve-dup-deps --mode=link gcc -export-dynamic -g -O2 -L/usr/local/lib -L/usr/lib/mysql -R /usr/local/lib -R /usr/lib/mysql ext/openssl/openssl.lo ext/zlib/zlib.lo ext/zlib/zlib_fopen_wrapper.lo ext/bcmath/bcmath.lo ext/bcmath/libbcmath/src/add.lo ext/bcmath/libbcmath/src/div.lo ext/bcmath/libbcmath/src/init.lo ext/bcmath/libbcmath/src/neg.lo ext/bcmath/libbcmath/src/outofmem.lo ext/bcmath/libbcmath/src/raisemod.lo ext/bcmath/libbcmath/src/rt.lo ext/bcmath/libbcmath/src/sub.lo ext/bcmath/libbcmath/src/compare.lo ext/bcmath/libbcmath/src/divmod.lo ext/bcmath/libbcmath/src/int2num.lo ext/bcmath/libbcmath/src/num2long.lo ext/bcmath/libbcmath/src/output.lo ext/bcmath/libbcmath/src/recmul.lo ext/bcmath/libbcmath/src/sqrt.lo ext/bcmath/libbcmath/src/zero.lo ext/bcmath/libbcmath/src/debug.lo ext/bcmath/libbcmath/src/doaddsub.lo ext/bcmath/libbcmath/src/nearzero.lo ext/bcmath/libbcmath/src/num2str.lo ext/bcmath/libbcmath/src/raise.lo ext/bcmath/libbcmath/src/rmzero.lo ext/bcmath/libbcmath/src/str2num.lo ext/calendar/calendar.lo ext/calendar/dow.lo ext/calendar/french.lo ext/calendar/gregor.lo ext/calendar/jewish.lo ext/calendar/julian.lo ext/calendar/easter.lo ext/calendar/cal_unix.lo ext/ctype/ctype.lo ext/curl/curl.lo ext/curl/curlstreams.lo ext/ftp/php_ftp.lo ext/ftp/ftp.lo ext/gd/gd.lo ext/gd/gdttf.lo ext/gd/gdcache.lo ext/gettext/gettext.lo ext/mcrypt/mcrypt.lo ext/mhash/mhash.lo ext/mysql/php_mysql.lo ext/overload/overload.lo ext/pcre/pcrelib/maketables.lo ext/pcre/pcrelib/get.lo ext/pcre/pcrelib/study.lo ext/pcre/pcrelib/pcre.lo ext/pcre/php_pcre.lo ext/posix/posix.lo ext/session/session.lo ext/session/mod_files.lo ext/session/mod_mm.lo ext/session/mod_user.lo ext/sockets/sockets.lo regex/regcomp.lo regex/regexec.lo regex/regerror.lo regex/regfree.lo ext/standard/array.lo ext/standard/base64.lo ext/standard/basic_functions.lo ext/standard/browscap.lo ext/standard/crc32.lo ext/standard/crypt.lo ext/standard/cyr_convert.lo ext/standard/datetime.lo ext/standard/dir.lo ext/standard/dl.lo ext/standard/dns.lo ext/standard/exec.lo ext/standard/file.lo ext/standard/filestat.lo ext/standard/flock_compat.lo ext/standard/formatted_print.lo ext/standard/fsock.lo ext/standard/head.lo ext/standard/html.lo ext/standard/image.lo ext/standard/info.lo ext/standard/iptc.lo ext/standard/lcg.lo ext/standard/link.lo ext/standard/mail.lo ext/standard/math.lo ext/standard/md5.lo ext/standard/metaphone.lo ext/standard/microtime.lo ext/standard/pack.lo ext/standard/pageinfo.lo ext/standard/parsedate.lo ext/standard/quot_print.lo ext/standard/rand.lo ext/standard/reg.lo ext/standard/soundex.lo ext/standard/string.lo ext/standard/scanf.lo ext/standard/syslog.lo ext/standard/type.lo ext/standard/uniqid.lo ext/standard/url.lo ext/standard/url_scanner.lo ext/standard/var.lo ext/standard/versioning.lo ext/standard/assert.lo ext/standard/strnatcmp.lo ext/standard/levenshtein.lo ext/standard/incomplete_class.lo ext/standard/url_scanner_ex.lo ext/standard/ftp_fopen_wrapper.lo ext/standard/http_fopen_wrapper.lo ext/standard/php_fopen_wrapper.lo ext/standard/credits.lo ext/standard/css.lo ext/standard/var_unserializer.lo ext/standard/ftok.lo ext/standard/aggregation.lo ext/standard/sha1.lo ext/tokenizer/tokenizer.lo ext/xml/xml.lo ext/xml/expat/xmlparse.lo ext/xml/expat/xmlrole.lo ext/xml/expat/xmltok.lo ext/zip/zip.lo TSRM/TSRM.lo TSRM/tsrm_strtok_r.lo TSRM/tsrm_virtual_cwd.lo main/main.lo main/snprintf.lo main/spprintf.lo main/php_sprintf.lo main/safe_mode.lo main/fopen_wrappers.lo main/alloca.lo main/php_scandir.lo main/php_ini.lo main/SAPI.lo main/rfc1867.lo main/php_content_types.lo main/strlcpy.lo main/strlcat.lo main/mergesort.lo main/reentrancy.lo main/php_variables.lo main/php_ticks.lo main/streams.lo main/network.lo main/php_open_temporary_file.lo main/php_logos.lo main/output.lo main/memory_streams.lo main/user_streams.lo Zend/zend_language_parser.lo Zend/zend_language_scanner.lo Zend/zend_ini_parser.lo Zend/zend_ini_scanner.lo Zend/zend_alloc.lo Zend/zend_compile.lo Zend/zend_constants.lo Zend/zend_dynamic_array.lo Zend/zend_execute_API.lo Zend/zend_highlight.lo Zend/zend_llist.lo Zend/zend_opcode.lo Zend/zend_operators.lo Zend/zend_ptr_stack.lo Zend/zend_stack.lo Zend/zend_variables.lo Zend/zend.lo Zend/zend_API.lo Zend/zend_extensions.lo Zend/zend_hash.lo Zend/zend_list.lo Zend/zend_indent.lo Zend/zend_builtin_functions.lo Zend/zend_sprintf.lo Zend/zend_ini.lo Zend/zend_qsort.lo Zend/zend_multibyte.lo Zend/zend_strtod.lo Zend/zend_execute.lo sapi/cli/php_cli.lo sapi/cli/getopt.lo main/internal_functions_cli.lo -lcrypt -lzzip -lcrypt -lmysqlclient -lmhash -lmcrypt -lltdl -lgd -lfreetype -lpng -lz -ljpeg -lcurl -lz -lssl -lcrypto -lresolv -lm -ldl -lnsl -lcurl -lssl -lcrypto -ldl -lz -lcrypt -lcrypt -o sapi/cli/php
ext/gd/gd.lo(.text+0x1267): In function `zif_imagecolormatch':
/usr/local/directadmin/customapache/php-4.3.10/ext/gd/gd.c:807: undefined reference to `gdImageColorMatch'
ext/gd/gd.lo(.text+0x2cd4): In function `zif_imagerotate':
/usr/local/directadmin/customapache/php-4.3.10/ext/gd/gd.c:1117: undefined reference to `gdImageRotate'
ext/gd/gd.lo(.text+0x5c21): In function `zif_imageline':
/usr/local/directadmin/customapache/php-4.3.10/ext/gd/gd.c:2191: undefined reference to `gdImageAALine'
ext/gd/gd.lo(.text+0x6ca8): In function `zif_imageellipse':
/usr/local/directadmin/customapache/php-4.3.10/ext/gd/gd.c:2324: undefined reference to `gdImageEllipse'
ext/gd/gd.lo(.text+0x9d94): In function `zif_imageantialias':
/usr/local/directadmin/customapache/php-4.3.10/ext/gd/gd.c:3885: undefined reference to `gdImageAntialias'
collect2: ld returned 1 exit status
make: *** [sapi/cli/php] Error 1
