Problem with compile PHP with CustomBuild
NEXEL
Hi, I have a problem with the installation. I'm doing one time in turn and I have the same error, I do not know how to solve it. Please help.
Installation DirectAdmin/CustomBuild/server LightServer etc.
Generating phar.php
/usr/local/directadmin/custombuild/php-7.2.8/sapi/cli/php: error while loading shared libraries: libicudata.so.58: cannot open shared object file: No such file or directory
Makefile:435: recipe for target 'ext/phar/phar.php' failed
make: *** [ext/phar/phar.php] Error 127
make: *** Waiting for unfinished jobs....
Cannot find /usr/local/bin/php
Please recompile php with custombuild, eg:
./build all d
This appears to be a 64-bit system.
a common cause of http/php compile failures is mentioned here:
http://help.directadmin.com/item.php?id=213
root@directadmin:~#
LDD
root@directadmin:~# ldd /usr/local/directadmin/custombuild/php-7.2.8/sapi/cli/php
        linux-vdso.so.1 (0x00007ffcf29a2000)
        libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f3e59b48000)
        libexslt.so.0 => /usr/local/lib/libexslt.so.0 (0x00007f3e59934000)
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f3e59730000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f3e59392000)
        libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007f3e59177000)
        libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f3e58de9000)
        libjpeg.so.9 => /usr/local/lib/libjpeg.so.9 (0x00007f3e58bae000)
        libpcre.so.0 => /usr/local/lib/libpcre.so.0 (0x00007f3e5893d000)
        libssl.so.1.1 => /usr/lib/x86_64-linux-gnu/libssl.so.1.1 (0x00007f3e586d3000)
        libcrypto.so.1.1 => /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1 (0x00007f3e5825b000)
        libcurl.so.4 => /usr/local/lib/libcurl.so.4 (0x00007f3e57fe8000)
        libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x00007f3e57d42000)
        libpng16.so.16 => /usr/local/lib/libpng16.so.16 (0x00007f3e57b0f000)
        libicui18n.so.58 => /usr/local/icu/lib/libicui18n.so.58 (0x00007f3e57699000)
        libicuuc.so.58 => /usr/local/icu/lib/libicuuc.so.58 (0x00007f3e572ef000)
        libicuio.so.58 => /usr/local/icu/lib/libicuio.so.58 (0x00007f3e570e1000)
        libxslt.so.1 => /usr/local/lib/libxslt.so.1 (0x00007f3e56ea1000)
        libxml2.so.2 => /usr/local/lib/libxml2.so.2 (0x00007f3e56b3e000)
        libiconv.so.2 => /usr/local/lib/libiconv.so.2 (0x00007f3e56841000)
        libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f3e56629000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f3e56238000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f3e5ae95000)
        libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f3e56019000)
        libicudata.so.58 => not found
