I downloaded the plugin and seen that you just need to enumerate the installed packages and retrieve their info data.
Exactly as this program does (together with many other things):
http://pear.php.net/package/PEAR_Frontend_Web/download
I've searched for any occurrence of "exec", "shell", "system" or "popen" in that code:
tillo@pctillo ~/PROGRAMMI/PEAR_Frontend_Web-0.7.3 $ grep -R -e popen -e exec -e shell -e system .
./pearfrontendweb.php: // TODO: doesn't work yet ! There is no way to find the system config
As you can see, they have been concerned about security.
The bottom line is that it is perfectly possible to retrieve any information (AND execute any command, like build/install/remove) about PEAR packages through their exporting library: see this in the main php file:
require_once 'PEAR/Frontend.php';
require_once 'PEAR/Command.php';
Unfortunately I've no time to help you more then that
sorry.
I hope (for
nemafire) that you will take a moment to make the script non-dependent on exec().
Oh, and another interesting thing:
tillo@less:~$ file /usr/local/php5/bin/pear
/usr/local/php5/bin/pear: Bourne shell script text executable
tillo@less:~$ tail -n 1 /usr/local/php5/bin/pear
exec $PHP -C -q $INCARG -d output_buffering=1 -d variables_order=EGPCS -d open_basedir="" -d safe_mode=0 -d register_argc_argv="On" -d auto_prepend_file="" -d auto_append_file="" $INCDIR/pearcmd.php "$@"
tillo@less:~$ locate pearcmd.php
/usr/local/lib/php/pearcmd.php
The pear binary you are executing... it's just a script launching another PHP script
maybe you can include that, don't know.
