Problem with "Disk Quota Exceeded"
JuLa
Hi.
I have problem with "Disk Quote Exceeded" and i found out that this is caused by to many Inodes.
I did a
and noticed that i have a lot of files in /usr/local/directadmin/data/tickets/. What is this and is it secure to delete these. If so, what is the right commands for this.
BR
Jula (Just one more beginner9
You should delete tickets from the ticket system. I don't know if deleting them from the shell will cause problems or not because I don't know if there's an index anywhere.
However, the tickets are owned by user diradmin, and user diradmin shouldn't have a quota.
Cant see this in DA
Hi Jeff and thanks for the replay.
I cant see anything in the ticket system so i cant delete these from DA.
Do you now what command to use if deleting from shell.
It look like this:
[root@vpsxxxxx tickets]# dir
000000  000001  000002  000003  000004  000005  000006  000007  000008  000009
And:
[root@vpsxxxxx 000009]# dir
9000  9008  9016  9024  9032  9040  9048  9056  9064  9072  9080  9088  9096  9104  9112  9120  9128  9136  9144  9152  9160  9168  9176  9184  9192  9200  9208
9001  9009  9017  9025  9033  9041  9049  9057  9065  9073  9081  9089  9097  9105  9113  9121  9129  9137  9145  9153  9161  9169  9177  9185  9193  9201  9209
9002  9010  9018  9026  9034 and so on
BR
JuLa
