Problem with DNS Management
moji
Hello my friends
I changed my dedicated server 4 days ago and change ip server on A Record domain panel but after 72h not changed. please help me, Which part do you think is wrong?
[ Screenshot ]
https://ibb.co/crHWsa
Check your admin level.
The vs1 and vs2 do not have the trailing dot like in the user level.
Nameservers are still pointing to the wrong ip (79.x.x.x.). So I hope the place in the domain panel were you made the A records for you nameservers is correct.
I should start changing the names ad the adminlevel so it will get the trailing dot.
It seems to me you should change IP for vs1 and vs2 at the domain's registrar. WHOIS shows:
Registrar WHOIS Server: whois.regtons.com
Registrar URL: http://regtons.com
Nameservers vs1 and vs2 are still pointing to old server IP address as per below ping. :)
Pinging vs1.ttsuploadin.com [79.124.56.26] with 32 bytes of data:
Pinging vs2.ttsuploadin.com [79.124.56.26] with 32 bytes of data:
