klikohost
- Aug 3, 2020
Hello to all i have problem with updating all those software Exim, SpamAssassin, ClamAV, MySQL, PHP 7.3.
Then i try to update from DA using Extra Features > CustomBuild 2.0 > UPDATE ALL i see to many errors.
All Websites working perfect but i cant update any software.
I using DA in Ubuntu
Thank try to update i accept those errors
And now any email that i send not accepted by emails and then go to
Thank you for understand me and helped me.
- Executing /usr/local/directadmin/plugins/custombuild/admin/build update_versions...
- [1mUpdating Exim(B[m
- Found /usr/local/directadmin/custombuild/exim-4.85.tar.gz
- Extracting ...
- Done.
- [1mCustom /usr/local/directadmin/custombuild/custom/exim/Makefile being used(B[m
- Trying to make exim...
- /bin/sh scripts/source_checks
- >>> Creating links to source files...
- >>> Creating lookups/Makefile for building dynamic modules
- >>> New Makefile & lookups/Makefile installed
- >>> Use "make makefile" if you need to force rebuilding of the makefile
- make[1]: warning: -j8 forced in submake: resetting jobserver mode.
- make[1]: Entering directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64'
- /bin/sh ../scripts/Configure-os.h
- /bin/sh ../scripts/Configure-os.c
- gcc buildconfig.c
- >>> version 4.85 #2
- >>> exigrep script built
- >>> exipick script built
- >>> exiqgrep script built
- >>> eximstats script built
- >>> exiqsumm script built
- gcc exim_lock.c
- >>> transport-filter.pl script built
- >>> convert4r3 script built
- >>> convert4r4 script built
- gcc -o exim_lock
- >>> exim_lock utility built
- /bin/sh ../scripts/Configure-config.h "make"
- make[2]: Entering directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64'
- make[2]: 'buildconfig' is up to date.
- make[2]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64'
- Building configuration file config.h
- >>> config.h built
- gcc exim_dbmbuild.c
- gcc -DEXIM_DUMPDB exim_dbutil.c
- gcc -DCOMPILE_UTILITY os.c
- gcc -DCOMPILE_UTILITY store.c
- >>> exinext script built
- gcc -DEXIM_FIXDB exim_dbutil.c
- >>> exicyclog script built
- >>> exim_checkaccess script built
- >>> exiwhat script built
- gcc -DEXIM_TIDYDB exim_dbutil.c
- make[2]: Entering directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/auths'
- make[2]: warning: -j8 forced in submake: resetting jobserver mode.
- make[2]: Entering directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/lookups'
- gcc auth-spa.c
- gcc cdb.c
- gcc dbmdb.c
- gcc b64decode.c
- gcc b64encode.c
- gcc call_pam.c
- gcc dnsdb.c
- gcc lsearch.c
- gcc call_pwcheck.c
- gcc call_radius.c
- gcc spf.c
- gcc lf_quote.c
- gcc check_serv_cond.c
- gcc lf_check_file.c
- gcc cram_md5.c
- gcc lf_sqlperform.c
- make[2]: Entering directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/pdkim'
- gcc base64.c
- gcc cyrus_sasl.c
- gcc bignum.c
- make[2]: Entering directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/transports'
- make[2]: Entering directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/routers'
- gcc acl.c
- gcc pdkim.c
- gcc rsa.c
- gcc accept.c
- gcc dnslookup.c
- gcc child.c
- gcc appendfile.c
- gcc autoreply.c
- gcc sha1.c
- gcc sha2.c
- gcc dovecot.c
- gcc ipliteral.c
- gcc lmtp.c
- gcc iplookup.c
- gcc pipe.c
- gcc get_data.c
- gcc manualroute.c
- gcc queryprogram.c
- gcc smtp.c
- gcc get_no64_data.c
- gcc tf_maildir.c
- gcc gsasl_exim.c
- gcc redirect.c
- gcc rf_change_domain.c
- gcc heimdal_gssapi.c
- gcc crypt16.c
- gcc md5.c
- gcc rf_expand_data.c
- gcc daemon.c
- gcc dbfn.c
- ar cq lookups.a
- gcc plaintext.c
- gcc pwcheck.c
- ranlib lookups.a
- gcc rf_get_errors_address.c
- make[2]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/lookups'
- gcc debug.c
- gcc sha1.c
- gcc rf_get_munge_headers.c
- gcc spa.c
- gcc xtextdecode.c
- gcc rf_get_transport.c
- gcc rf_get_ugid.c
- gcc xtextencode.c
- gcc rf_lookup_hostlist.c
- gcc rf_queue_add.c
- gcc rf_self_action.c
- gcc rf_set_ugid.c
- gcc deliver.c
- gcc directory.c
- ar cq auths.a
- ranlib auths.a
- make[2]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/auths'
- gcc dns.c
- ar cq routers.a
- ranlib routers.a
- make[2]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/routers'
- gcc drtables.c
- gcc enq.c
- ar cq pdkim.a
- ranlib pdkim.a
- make[2]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/pdkim'
- gcc exim.c
- ar cq transports.a
- ranlib transports.a
- make[2]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64/transports'
- gcc expand.c
- gcc filter.c
- gcc filtertest.c
- gcc globals.c
- gcc dkim.c
- gcc header.c
- gcc host.c
- gcc ip.c
- gcc log.c
- gcc lss.c
- gcc match.c
- gcc moan.c
- gcc os.c
- gcc parse.c
- gcc queue.c
- gcc rda.c
- gcc readconf.c
- gcc receive.c
- gcc retry.c
- gcc rewrite.c
- gcc rfc2047.c
- gcc route.c
- gcc search.c
- gcc sieve.c
- gcc smtp_in.c
- gcc smtp_out.c
- gcc spool_in.c
- gcc spool_out.c
- gcc std-crypto.c
- gcc store.c
- gcc string.c
- gcc tls.c
- gcc tod.c
- gcc transport.c
- gcc tree.c
- gcc verify.c
- tod.c: In function 'tod_stamp':
- tod.c:97:55: warning: ':' directive writing 1 byte into a region of size between 0 and 16 [-Wformat-overflow=]
- 97 | (void) sprintf(CS timebuf, "%04d-%02d-%02d %02d:%02d:%02d",
- In file included from /usr/include/stdio.h:867,
- from exim.h:71,
- from tod.c:11:
- /usr/include/x86_64-linux-gnu/bits/stdio2.h:36:10: note: '__builtin___sprintf_chk' output between 20 and 72 bytes into a destination of size 32
- 36 | return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1,
- 37 | __bos (__s), __fmt, __va_arg_pack ());
- tod.c:165:59: warning: ':' directive writing 1 byte into a region of size between 0 and 16 [-Wformat-overflow=]
- 165 | (void) sprintf(CS timebuf, "%04d-%02d-%02d %02d:%02d:%02d %+03d%02d",
- tod.c:165:34: note: directive argument in the range [-35791394, 35791394]
- tod.c:165:34: note: directive argument in the range [0, 2147483647]
- from exim.h:71,
- from tod.c:11:
- /usr/include/x86_64-linux-gnu/bits/stdio2.h:36:10: note: '__builtin___sprintf_chk' output between 26 and 92 bytes into a destination of size 32
- gcc lookups/lf_quote.c
- gcc lookups/lf_check_file.c
- gcc lookups/lf_sqlperform.c
- In file included from tls.c:120:
- tls-openssl.c: In function 'rsa_callback':
- tls-openssl.c:222:1: warning: 'RSA_generate_key' is deprecated [-Wdeprecated-declarations]
- 222 | rsa_key = RSA_generate_key(keylength, RSA_F4, NULL, NULL);
- In file included from /usr/include/openssl/e_os2.h:13,
- from /usr/include/openssl/lhash.h:17,
- from tls-openssl.c:21,
- from tls.c:120:
- /usr/include/openssl/rsa.h:235:1: note: declared here
- 235 | DEPRECATEDIN_0_9_8(RSA *RSA_generate_key(int bits, unsigned long e, void
- tls-openssl.c: In function 'tls_client_stapling_cb':
- tls-openssl.c:1057:45: error: dereferencing pointer to incomplete type 'OCSP_BASICRESP' {aka 'struct ocsp_basic_response_st'}
- 1057 | STACK_OF(OCSP_SINGLERESP) * sresp = bs->tbsResponseData->responses;
- tls-openssl.c: In function 'vaguely_random_number':
- tls-openssl.c:2407:1: warning: 'RAND_pseudo_bytes' is deprecated [-Wdeprecated-declarations]
- 2407 | i = RAND_pseudo_bytes(smallbuf, needed_len);
- from tls.c:120:
- /usr/include/openssl/rand.h:44:1: note: declared here
- 44 | DEPRECATEDIN_1_1_0(int RAND_pseudo_bytes(unsigned char *buf, int num))
- gcc local_scan.c
- In file included from tls.c:121:
- tlscert-openssl.c: In function 'tls_cert_ext_by_oid':
- tlscert-openssl.c:310:1: warning: implicit declaration of function 'M_ASN1_OCTET_STRING_print'; did you mean 'ASN1_OCTET_STRING_set'? [-Wimplicit-function-declaration]
- 310 | M_ASN1_OCTET_STRING_print(bp, adata);
- | ASN1_OCTET_STRING_set
- tlscert-openssl.c: In function 'tls_cert_subject_altname':
- tlscert-openssl.c:363:7: warning: 'ASN1_STRING_data' is deprecated [-Wdeprecated-declarations]
- 363 | ele = ASN1_STRING_data(namePart->d.dNSName);
- from tls.c:120:
- /usr/include/openssl/asn1.h:554:1: note: declared here
- 554 | DEPRECATEDIN_1_1_0(unsigned char *ASN1_STRING_data(ASN1_STRING *x))
- tlscert-openssl.c:368:7: warning: 'ASN1_STRING_data' is deprecated [-Wdeprecated-declarations]
- 368 | ele = ASN1_STRING_data(namePart->d.uniformResourceIdentifier);
- from tls.c:120:
- tlscert-openssl.c:373:7: warning: 'ASN1_STRING_data' is deprecated [-Wdeprecated-declarations]
- 373 | ele = ASN1_STRING_data(namePart->d.rfc822Name);
- from tls.c:120:
- tlscert-openssl.c: In function 'tls_cert_ocsp_uri':
- tlscert-openssl.c:410:8: warning: 'ASN1_STRING_data' is deprecated [-Wdeprecated-declarations]
- 410 | ASN1_STRING_data(ad->location->d.ia5));
- from tls.c:120:
- tlscert-openssl.c: In function 'tls_cert_crl_uri':
- tlscert-openssl.c:443:3: warning: 'ASN1_STRING_data' is deprecated [-Wdeprecated-declarations]
- 443 | ASN1_STRING_data(np->d.uniformResourceIdentifier));
- from tls.c:120:
- x86_64-linux-gnu-gcc perl.c
- make[1]: *** [Makefile:581: tls.o] Error 1
- make[1]: *** Waiting for unfinished jobs....
- make[1]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.85/build-Linux-x86_64'
- make: *** [Makefile:29: all] Error 2
- Done!
Mail Queue Administration
But then i send from others emails servers i accept the email normaly.Thank you for understand me and helped me.
