Several of my users told me about the problem with the fclose() function of php. They gave me a small php script which shows that the function works only for the second time. Since my users are using a function md5_file() in their scripts, the results they are not loyal to. This is a serious problem that I can not decide. Server software: OS FreeBSD 7.1, apache 2.2 + php 5.2.10 (installed through custombuild)
php script example:
Result:
Also, I checked the script work on another server, that is running OS FreeBSD 7.1 and apache 2.0 + php 5.2.9 installed from ports collection. And I don't have any problems with script work on this server.
Anybody has faced this problem and whether there was a problem on servers with linux OS?
Thx.
Ihor R.
php script example:
PHP:
function curl_redir_exec($ch)
static $curl_loops = 0;
static $curl_max_loops = 20;
if ($curl_loops++ >= $curl_max_loops)
$curl_loops = 0;
return FALSE;
curl_setopt($ch, CURLOPT_HEADER, true);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$data = curl_exec($ch);
list($header, $data) = explode("\n\n", $data, 2);
$http_code = curl_getinfo($ch, CURLINFO_HTTP_CODE);
if ($http_code == 301 || $http_code == 302)
$matches = array();
preg_match('/Location:(.*?)\n/', $header, $matches);
$url = @parse_url(trim(array_pop($matches)));
if (!$url)
//couldn't process the url to redirect to
$curl_loops = 0;
return $data;
$last_url = parse_url(curl_getinfo($ch, CURLINFO_EFFECTIVE_URL));
if (!$url['scheme'])
$url['scheme'] = $last_url['scheme'];
if (!$url['host'])
$url['host'] = $last_url['host'];
if (!$url['path'])
$url['path'] = $last_url['path'];
$new_url = $url['scheme'] . '://' . $url['host'] . $url['path'] . ($
curl_setopt($ch, CURLOPT_URL, $new_url);
return $new_url;
} else {
$curl_loops=0;
return $data;
echo md5_file('icq.gif').' : 1<br>'; //1
$icq_link=curl_init("http://status.icq.com/online.gif?icq=53907547&img=27");
$icq_file=fopen('icq.gif', 'w');
$url_link=curl_redir_exec($icq_link);
echo $url_link."<br />";
$icq_link=curl_init("$url_link");
curl_setopt($icq_link, CURLOPT_FILE, $icq_file);
curl_setopt($icq_link, CURLOPT_HEADER, 0);
curl_exec($icq_link);
curl_close($icq_link);
$result=fclose($icq_file);
echo "Fclose result: ".$result."<br />";
echo md5_file('icq.gif').' :2<br>'; //1
$icq_file=fopen('icq.gif', 'r');
echo md5_file('icq.gif').' :3<br>'; //1
echo md5_file('icq.gif').' :4<br>';
Result:
57349976dfb9ff183c2fd69907e0b16f : 1
http://status.icq.com/27/online1.gif
Fclose result: 1
d41d8cd98f00b204e9800998ecf8427e :2
57349976dfb9ff183c2fd69907e0b16f :3
Fclose result: 1
57349976dfb9ff183c2fd69907e0b16f :4
Thx.
Ihor R.
