problem with httpd
adamp
hello ihave problem with httpd i do restart to httpd and get this error:
root@server ~]# service httpd restart
Stopping httpd: [FAILED]
Starting httpd: httpd: bad user name xxxx
[FAILED]
what can i do??/
thanks for help
Make sure that user/account is still one your clients. If not, remove it from your httpd.conf file and restart httpd.
// generated by named-bootconf.pl
options {
recursion no;
directory "/var/named";
* If there is a firewall between you and nameservers you want
* to talk to, you might need to uncomment the query-source
* directive below. Previous versions of BIND always asked
* questions using port 53, but BIND 8.1 uses an unprivileged
* port by default.
// query-source address * port 53;
// a caching only nameserver config
controls {
inet 127.0.0.1 allow { localhost; } keys { rndckey; };
zone "." IN {
type hint;
file "named.ca";
zone "localhost" IN {
type master;
file "localhost.zone";
allow-update { none; };
zone "0.0.127.in-addr.arpa" IN {
type master;
file "named.local";
include "/etc/rndc.key";
this is file name.conf
i don'wt understand it's ok...
i fixed problem i remove all user from admin level> show all user
