S SevenHost New member Joined Jan 11, 2023 Messages 3 Jan 11, 2023 #1 Hey! When I try to connect my panel to the WHMCS billing panel, I get this kind of error 7 - Failed to connect to server-185-251-88-152.da.direct port 2222 after 1000 ms: Connection refused I even tried disabling the firewall, didn't help.
O Ohm J Verified User Joined Aug 16, 2019 Messages 1,810 Jan 11, 2023 #2 please setup your server hostname, don't use that to connect server. Because it can only use on local, not for public.
S SevenHost New member Joined Jan 11, 2023 Messages 3 Jan 11, 2023 #3 configured but I also get the same problem 7 - Failed to connect to cp.sevenseller.com port 2222 after 1002 ms: Connection refused
O Ohm J Verified User Joined Aug 16, 2019 Messages 1,810 Jan 12, 2023 #4 did you pointer your hostname to your server IP ? before you connect with API, please makesure you can connect with your web browser.
S SevenHost New member Joined Jan 11, 2023 Messages 3 Jan 12, 2023 #5 Yes, I can connect through the browser, but the API does not work, what could be the problem?
O Ohm J Verified User Joined Aug 16, 2019 Messages 1,810 Jan 12, 2023 #6 possible firewall from your whmcs server ?
