Problem with IP's
lidorit2k
Hello, i added few IP's for my Dedicated Server from DA
everything was ok.. but after the server had a reboot
only the first IP is working..
now when im trying to add IP's on DA im getting error
"IP **** is alredy exists on eth0"
i go back to the IP's Manager on DA and i see the ip i tryed to added
but i cannot use him.. hes not working :|
what can i do?
can you check ifconfig in ssh shell and see if the IPs are really in use?
/usr/local/directadmin/data/admin/ip.list contains the list of your IPs.
you should also check here: /usr/local/directadmin/data/admin/ips
you should see there are some small files there with your secondary IP addresses as filename. Check the file 1 by 1 and make sure the information (gw/subnet..etc) you input is correct. This is where DA added your secondary IPs.
