Problem with let's encrypt
Lanak
I cannot get a certificate. I am using DA 1.53.4, CB 2.0.0 (rev: 1907), LE 1.1.10.
I checked the domain's A and MX records. They are all there, but somehow I still got this error. Could someone point me in the right direction please?
Cannot Execute Your Request
Generating 4096 bit RSA key for let's encrypt account...
openssl genrsa 4096 > "/usr/local/directadmin/conf/letsencrypt.key"
Generating RSA private key, 4096 bit long modulus
e is 65537 (0x10001)
Account registration error. Response: HTTP/1.1 100 Continue
Expires: Sun, 19 Aug 2018 06:22:57 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
HTTP/1.1 400 Bad Request
Server: nginx
Content-Type: application/problem+json
Content-Length: 178
Replay-Nonce: 5HXkGmrlWxHCLTAtnDSIMh6WWPvVupM9Qg8YMLw9-W0
Pragma: no-cache
Date: Sun, 19 Aug 2018 06:22:57 GMT
Connection: close
"type": "urn:ietf:params:acme:error:invalidEmail",
"detail": "Error creating new account :: empty DNS response validating email domain - no MX/A records",
"status": 400
It worked with an older version of Letsencrypt. Seems something is not always going correctly with the record checks some way.
Thanks. I did go back to an older version (LE 1.0.21) and that worked fine.
I have a simular problem with Direct admin and Lets encrypt. The error is the same:
"status": 400
But in my case the issue is that when I want to request a certificate the e-mail field is missing. 4 weeks ago it was working because I added 2 websites with ssl. Now it's a problem so I think it's an update. I tried to downgrade Lets encrypt, but this was no solution. My other servers also has no issues so I'm stuck with this one. Anyone a tip?
hmmm........that make sense for that part. But how can I fix this error?
UPDATE
Fixed it, I never had filled in a working mail adres for the admin user. After changing the mail adress for admin it works :-)
Working fine with "Upgrade Let's Encrypt"
run with root, you can upgrade custombuild too
# cd /usr/local/directadmin/custombuild; ./build update; ./build letsencrypt;
then
# service directadmin restart
and try again
