problem
2012:07:30-14:25:50: Timeout from from 153.19.131.218 : last flagged: Command::doCommand(/CMD_MAIL_QUEUE)
2012:07:30-14:25:51: Timeout from from 153.19.131.218 : last flagged: Command::doCommand(/CMD_MAIL_QUEUE)
2012:07:31-11:02:18: Auth:
assValid: unable to get user_info for Admin
2012:08:01-11:13:49: unable to stat ./data/admin/login.hist.temp for filesize after write: euid:103
2012:08:01-11:13:49: Unable to write ./data/admin/login.hist: Unable to stat ./data/admin/login.hist.temp for filesize after write<br>
ConfigFile::removeFile(./data/admin/login.hist) filename does not match<br>
2012:08:01-11:13:53: unable to stat /usr/local/directadmin/data/sessions/da_sess_4bboBh1vxIgCRiLSGM47LEIntGBa5N78xiu8Ot2JBgVaMr0aB4gXHwKACWjFtoNq.temp for filesize after write: euid:103
2012:08:01-11:13:53: Unable to write session file: Unable to open /usr/local/directadmin/data/sessions/da_sess_4bboBh1vxIgCRiLSGM47LEIntGBa5N78xiu8Ot2JBgVaMr0aB4gXHwKACWjFtoNq for reading.<br>
Unable to stat /usr/local/directadmin/data/sessions/da_sess_4bboBh1vxIgCRiLSGM47LEIntGBa5N78xiu8Ot2JBgVaMr0aB4gXHwKACWjFtoNq.temp for filesize after write<br>
ConfigFile::removeFile(/usr/local/directadmin/data/sessions/da_sess_4bboBh1vxIgCRiLSGM47LEIntGBa5N78xiu8Ot2JBgVaMr0aB4gXHwKACWjFtoNq) filename does not match<br>
. Make sure the disk isn't full.
2012:08:01-11:13:53: Unable to write session file: Unable to read session file: Unable to open /usr/local/directadmin/data/sessions/da_sess_4bboBh1vxIgCRiLSGM47LEIntGBa5N78xiu8Ot2JBgVaMr0aB4g$
<br>
. Make sure the disk isn't full.<br>
2012:08:01-11:13:53: unable to stat ./data/admin/login.hist.temp for filesize after write: euid:103
2012:08:01-11:13:53: Unable to write ./data/admin/login.hist: Unable to stat ./data/admin/login.hist.temp for filesize after write<br>
2012:08:01-11:13:54: unable to stat /usr/local/directadmin/data/sessions/da_sess_ZBz0votmKD0kGSsz2Umy1RJ4mMTeT0O3BL347xqS8oCOG4OGW8CYZWaJq2yJ2KKB.temp for filesize after write: euid:103
2012:08:01-11:13:54: Unable to write session file: Unable to open /usr/local/directadmin/data/sessions/da_sess_ZBz0votmKD0kGSsz2Umy1RJ4mMTeT0O3BL347xqS8oCOG4OGW8CYZWaJq2yJ2KKB for reading.<br>
Unable to stat /usr/local/directadmin/data/sessions/da_sess_ZBz0votmKD0kGSsz2Umy1RJ4mMTeT0O3BL347xqS8oCOG4OGW8CYZWaJq2yJ2KKB.temp for filesize after write<br>
ConfigFile::removeFile(/usr/local/directadmin/data/sessions/da_sess_ZBz0votmKD0kGSsz2Umy1RJ4mMTeT0O3BL347xqS8oCOG4OGW8CYZWaJq2yJ2KKB) filename does not match<br>
2012:08:01-11:13:54: Unable to write session file: Unable to read session file: Unable to open /usr/local/directadmin/data/sessions/da_sess_ZBz0votmKD0kGSsz2Umy1RJ4mMTeT0O3BL347xqS8oCOG4OGW8C$
<br>
2012:08:01-11:13:54: unable to stat ./data/admin/login.hist.temp for filesize after write: euid:103
2012:08:01-11:13:54: Unable to write ./data/admin/login.hist: Unable to stat ./data/admin/login.hist.tem
