Problem with RAM
xuancong6000
could you tell me how can I know which software is running on my VPS by touch a command? because my VPS had install Directadmin,ClamAV and CSF Firewall .On server hosted 15 website and 1 day traffic about 1GB but it used 1.2GB of RAM
thanks
thanks
RAM memory has nothing to do with bandwidth...
If you install and update services with custombuild, type this
./build versions
After that, if you want to update everything, type this
./build update_versions
For more instructions and all available commands
./build help
problem
./build versions
./build help
when I complete that command it appear a problem:
[root@server custombuild]# ./build versions
Latest version of DirectAdmin: 1.41.1
Installed version of DirectAdmin: 1.41.1
Latest version of Apache: 2.2.23
Installed version of Apache: 2.2.23
Latest version of PCRE: 8.20
Installed version of PCRE: 8.20
Latest version of FreeType: 2.4.10
Installed version of FreeType: 2.4.10
Latest version of dovecot: 2.1.10
Installed version of dovecot: 2.1.10
Latest version of ClamAV: 0.97.6
Installed version of ClamAV: 0.97.1
ClamAV 0.97.1 to 0.97.6 update is available.
PHP:  Error parsing /usr/local/lib/php.ini on line 1106
Failed loading /usr/local/ioncube/ioncube_loader_lin_5.2.sozend_extension:  /usr/local/ioncube/ioncube_loader_lin_5.2.sozend_extension: cannot open shared object file: No such file or directory
Latest version of PHP (CLI): 5.2.17
Installed version of PHP (CLI): 5.2.17
Latest version of RoundCube webmail: 0.8.2
Installed version of RoundCube webmail: 0.8.2
Latest version of phpMyAdmin: 3.5.3-all-languages
Installed version of phpMyAdmin: 3.5.3-all-languages
Latest version of SquirrelMail: 1.4.22
Installed version of SquirrelMail: 1.4.22
If you want to update all the available versions run: ./build update_versions
this is my php.ini
You should use UBB code tags instead of uploading a file!
I modified your php.ini, use this one and have a nice day :)
[PHP]
; WARNING ;
; This is the default settings file for new PHP installations.
; By default, PHP installs itself with a configuration suitable for
; development purposes, and *NOT* for production purposes.
; For several security-oriented considerations that should be taken
; before going online with your site, please consult php.ini-recommended
; and http://php.net/manual/en/security.php.
; About this file ;
; This file controls many aspects of PHP's behavior.  In order for PHP to
; read it, it must be named 'php.ini'.  PHP looks for it in the current
; working directory, in the path designated by the environment variable
; PHPRC, and in the path that was defined in compile time (in that order).
; Under Windows, the compile-time path is the Windows directory.  The
; path in which the php.ini file is looked for can be overridden using
; the -c argument in command line mode.
; The syntax of the file is extremely simple.  Whitespace and Lines
; beginning with a semicolon are silently ignored (as you probably guessed).
; Section headers (e.g. [Foo]) are also silently ignored, even though
; they might mean something in the future.
; Directives are specified using the following syntax:
; directive = value
; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
; (e.g. E_ALL & ~E_NOTICE), or a quoted string ("foo").
; Expressions in the INI file are limited to bitwise operators and parentheses:
; |        bitwise OR
; &        bitwise AND
; ~        bitwise NOT
; !        boolean NOT
; Boolean flags can be turned on using the values 1, On, True or Yes.
; They can be turned off using the values 0, Off, False or No.
; An empty string can be denoted by simply not writing anything after the equal
; sign, or by using the None keyword:
;  foo =         ; sets foo to an empty string
;  foo = none    ; sets foo to an empty string
;  foo = "none"  ; sets foo to the string 'none'
; If you use constants in your value, and these constants belong to a
; dynamically loaded extension (either a PHP extension or a Zend extension),
; you may only use these constants *after* the line that loads the extension.
; All the values in the php.ini-dist file correspond to the builtin
; defaults (that is, if no php.ini is used, or if you delete these lines,
; the builtin defaults will be identical).
; Language Options ;
; Enable the PHP scripting language engine under Apache.
engine = On
; Allow the <? tag.  Otherwise, only <?php and <script> tags are recognized.
; NOTE: Using short tags should be avoided when developing applications or
; libraries that are meant for redistribution, or deployment on PHP
; servers which are not under your control, because short tags may not
; be supported on the target server. For portable, redistributable code,
; be sure not to use short tags.
short_open_tag = On
; Allow ASP-style <% %> tags.
asp_tags = Off
; The number of significant digits displayed in floating point numbers.
precision    =  12
; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
y2k_compliance = On
; Output buffering allows you to send header lines (including cookies) even
; after you send body content, at the price of slowing PHP's output layer a
; bit.  You can enable output buffering during runtime by calling the output
; buffering functions.  You can also enable output buffering for all files by
; setting this directive to On.  If you wish to limit the size of the buffer
; to a certain size - you can use a maximum number of bytes instead of 'On', as
; a value for this directive (e.g., output_buffering=4096).
output_buffering = Off
; You can redirect all of the output of your scripts to a function.  For
; example, if you set output_handler to "mb_output_handler", character
; encoding will be transparently converted to the specified encoding.
; Setting any output handler automatically turns on output buffering.
; Note: People who wrote portable scripts should not depend on this ini
;       directive. Instead, explicitly set the output handler using ob_start().
;       Using this ini directive may cause problems unless you know what script
;       is doing.
; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
;       and you cannot use both "ob_gzhandler" and "zlib.output_compression".
;output_handler =
; Transparent output compression using the zlib library
; Valid values for this option are 'off', 'on', or a specific buffer size
; to be used for compression (default is 4KB)
; Note: Resulting chunk size may vary due to nature of compression. PHP
;       outputs chunks that are few hundreds bytes each as a result of
;       compression. If you prefer a larger chunk size for better
;       performance, enable output_buffering in addition.
; Note: You need to use zlib.output_handler instead of the standard
;       output_handler, or otherwise the output will be corrupted.
zlib.output_compression = Off
; You cannot specify additional output handlers if zlib.output_compression
; is activated here. This setting does the same as output_handler but in
; a different order.
;zlib.output_handler =
; Implicit flush tells PHP to tell the output layer to flush itself
; automatically after every output block.  This is equivalent to calling the
; PHP function flush() after each and every call to print() or echo() and each
; and every HTML block.  Turning this option on has serious performance
; implications and is generally recommended for debugging purposes only.
implicit_flush = Off
; The unserialize callback function will be called (with the undefined class'
; name as parameter), if the unserializer finds an undefined class
; which should be instanciated.
; A warning appears if the specified function is not defined, or if the
; function doesn't include/implement the missing class.
; So only set this entry, if you really want to implement such a
; callback-function.
unserialize_callback_func=
; When floats & doubles are serialized store serialize_precision significant
; digits after the floating point. The default value ensures that when floats
; are decoded with unserialize, the data will remain the same.
serialize_precision = 100
; Safe Mode
;safe_mode = Off
; By default, Safe Mode does a UID compare check when
; opening files. If you want to relax this to a GID compare,
; then turn on safe_mode_gid.
;safe_mode_gid = Off
; When safe_mode is on, UID/GID checks are bypassed when
; including files from this directory and its subdirectories.
; (directory must also be in include_path or full path must
; be used when including)
;safe_mode_include_dir =
; When safe_mode is on, only executables located in the safe_mode_exec_dir
; will be allowed to be executed via the exec family of functions.
;safe_mode_exec_dir =
; Setting certain environment variables may be a potential security breach.
; This directive contains a comma-delimited list of prefixes.  In Safe Mode,
; the user may only alter environment variables whose names begin with the
; prefixes supplied here.  By default, users will only be able to set
; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
; Note:  If this directive is empty, PHP will let the user modify ANY
; environment variable!
;safe_mode_allowed_env_vars = PHP_
; This directive contains a comma-delimited list of environment variables that
; the end user won't be able to change using putenv().  These variables will be
; protected even if safe_mode_allowed_env_vars is set to allow to change them.
;safe_mode_protected_env_vars = LD_LIBRARY_PATH
; open_basedir, if set, limits all file operations to the defined directory
; and below.  This directive makes most sense if used in a per-directory
; or per-virtualhost web server configuration file. This directive is
; *NOT* affected by whether Safe Mode is turned On or Off.
;open_basedir =
; This directive allows you to disable certain functions for security reasons.
; It receives a comma-delimited list of function names. This directive is
disable_functions = exec,system,passthru,escapeshellarg,escapeshellcmd ,proc_close,dl,popen,show_source,popen,c url_multi_exec,parse_ini_file
; This directive allows you to disable certain classes for security reasons.
; It receives a comma-delimited list of class names. This directive is
disable_classes =
; Colors for Syntax Highlighting mode.  Anything that's acceptable in
; <font color="??????"> would work.
;highlight.string  = #DD0000
;highlight.comment = #FF9900
;highlight.keyword = #007700
;highlight.bg      = #FFFFFF
;highlight.default = #0000BB
;highlight.html    = #000000
; Misc
; Decides whether PHP may expose the fact that it is installed on the server
; (e.g. by adding its signature to the Web server header).  It is no security
; threat in any way, but it makes it possible to determine whether you use PHP
; on your server or not.
expose_php = On
; Resource Limits ;
max_execution_time = 30     ; Maximum execution time of each script, in seconds
max_input_time = 60	; Maximum amount of time each script may spend parsing request data
memory_limit = 32M      ; Maximum amount of memory a script may consume (32MB)
; Error handling and logging ;
; error_reporting is a bit-field.  Or each number up to get desired error
; reporting level
; E_ALL             - All errors and warnings
; E_ERROR           - fatal run-time errors
; E_WARNING         - run-time warnings (non-fatal errors)
; E_PARSE           - compile-time parse errors
; E_NOTICE          - run-time notices (these are warnings which often result
;                     from a bug in your code, but it's possible that it was
;                     intentional (e.g., using an uninitialized variable and
;                     relying on the fact it's automatically initialized to an
;                     empty string)
; E_CORE_ERROR      - fatal errors that occur during PHP's initial startup
; E_CORE_WARNING    - warnings (non-fatal errors) that occur during PHP's
;                     initial startup
; E_COMPILE_ERROR   - fatal compile-time errors
; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
; E_USER_ERROR      - user-generated error message
; E_USER_WARNING    - user-generated warning message
; E_USER_NOTICE     - user-generated notice message
; Examples:
;   - Show all errors, except for notices
;error_reporting = E_ALL & ~E_NOTICE
;   - Show only errors
;error_reporting = E_COMPILE_ERROR|E_ERROR|E_CORE_ERROR
;   - Show all errors except for notices
error_reporting = E_ALL & ~E_NOTICE & ~E_DEPRECATED
; Print out errors (as a part of the output).  For production web sites,
; you're strongly encouraged to turn this feature off, and use error logging
; instead (see below).  Keeping display_errors enabled on a production web site
; may reveal security information to end users, such as file paths on your Web
; server, your database schema or other information.
display_errors = On
; Even when display_errors is on, errors that occur during PHP's startup
; sequence are not displayed.  It's strongly recommended to keep
; display_startup_errors off, except for when debugging.
display_startup_errors = Off
; Log errors into a log file (server-specific log, stderr, or error_log (below))
; As stated above, you're strongly advised to use error logging in place of
; error displaying on production web sites.
log_errors = On
; Set maximum length of log_errors. In error_log information about the source is
; added. The default is 1024 and 0 allows to not apply any maximum length at all.
log_errors_max_len = 1024
; Do not log repeated messages. Repeated errors must occur in same file on same
; line until ignore_repeated_source is set true.
ignore_repeated_errors = Off
; Ignore source of message when ignoring repeated messages. When this setting
; is On you will not log errors with repeated messages from different files or
; sourcelines.
ignore_repeated_source = Off
; If this parameter is set to Off, then memory leaks will not be shown (on
; stdout or in the log). This has only effect in a debug compile, and if
; error reporting includes E_WARNING in the allowed list
report_memleaks = On
; Store the last error/warning message in $php_errormsg (boolean).
track_errors = Off
; Disable the inclusion of HTML tags in error messages.
;html_errors = Off
; If html_errors is set On PHP produces clickable error messages that direct
; to a page describing the error or function causing the error in detail.
; You can download a copy of the PHP manual from http://www.php.net/docs.php
; and change docref_root to the base URL of your local copy including the
; leading '/'. You must also specify the file extension being used including
; the dot.
;docref_root = "/phpmanual/"
;docref_ext = .html
; String to output before an error message.
;error_prepend_string = "<font color=ff0000>"
; String to output after an error message.
;error_append_string = "</font>"
; Log errors to specified file.
error_log = error_log
; Log errors to syslog (Event Log on NT, not valid in Windows 95).
;error_log = syslog
; Data Handling ;
; Note - track_vars is ALWAYS enabled as of PHP 4.0.3
; The separator used in PHP generated URLs to separate arguments.
; Default is "&".
;arg_separator.output = "&"
; List of separator(s) used by PHP to parse input URLs into variables.
; Default is "&".
; NOTE: Every character in this directive is considered as separator!
;arg_separator.input = ";&"
; This directive describes the order in which PHP registers GET, POST, Cookie,
; Environment and Built-in variables (G, P, C, E & S respectively, often
; referred to as EGPCS or GPC).  Registration is done from left to right, newer
; values override older values.
variables_order = "EGPCS"
; Whether or not to register the EGPCS variables as global variables.  You may
; want to turn this off if you don't want to clutter your scripts' global scope
; with user data.  This makes most sense when coupled with track_vars - in which
; case you can access all of the GPC variables through the $HTTP_*_VARS[],
; variables.
; You should do your best to write your scripts so that they do not require
; register_globals to be on;  Using form variables as globals can easily lead
; to possible security problems, if the code is not very well thought of.
;register_globals = Off
; This directive tells PHP whether to declare the argv&argc variables (that
; would contain the GET information).  If you don't use these variables, you
; should turn it off for increased performance.
register_argc_argv = On
; Maximum size of POST data that PHP will accept.
post_max_size = 8M
; This directive is deprecated.  Use variables_order instead.
gpc_order = "GPC"
; Magic quotes
; Magic quotes for incoming GET/POST/Cookie data.
;magic_quotes_gpc = Off
; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
;magic_quotes_runtime = Off
; Use Sybase-style magic quotes (escape ' with '' instead of \').
;magic_quotes_sybase = Off
; Automatically add files before or after any PHP document.
auto_prepend_file =
auto_append_file =
; As of 4.0b4, PHP always outputs a character encoding by default in
; the Content-type: header.  To disable sending of the charset, simply
; set it to be empty.
; PHP's built-in default is text/html
default_mimetype = "text/html"
;default_charset = "iso-8859-1"
; Always populate the $HTTP_RAW_POST_DATA variable.
;always_populate_raw_post_data = On
; Paths and Directories ;
; UNIX: "/path1:/path2"
include_path = ".:/usr/lib/php:/usr/local/lib/php"
; Windows: "\path1;\path2"
;include_path = ".;c:\php\includes"
; The root of the PHP pages, used only if nonempty.
; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
; if you are running php as a CGI under any web server (other than IIS)
; see documentation for security issues.  The alternate is to use the
; cgi.force_redirect configuration below
doc_root =
; The directory under which PHP opens the script using /~username used only
; if nonempty.
user_dir =
; Directory in which the loadable extensions (modules) reside.
extension_dir = "/usr/local/lib/php/extensions/no-debug-non-zts-20090626"
; Whether or not to enable the dl() function.  The dl() function does NOT work
; properly in multithreaded servers, such as IIS or Zeus, and is automatically
; disabled on them.
enable_dl = On
; cgi.force_redirect is necessary to provide security running PHP as a CGI under
; most web servers.  Left undefined, PHP turns this on by default.  You can
; turn it off here AT YOUR OWN RISK
; **You CAN safely turn this off for IIS, in fact, you MUST.**
; cgi.force_redirect = 1
; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
; every request.
; cgi.nph = 1
; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
; will look for to know it is OK to continue execution.  Setting this variable MAY
; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
; cgi.redirect_status_env = ;
; cgi.fix_pathinfo provides *real* PATH_INFO/PATH_TRANSLATED support for CGI.  PHP's
; previous behaviour was to set PATH_TRANSLATED to SCRIPT_FILENAME, and to not grok
; what PATH_INFO is.  For more information on PATH_INFO, see the cgi specs.  Setting
; this to 1 will cause PHP CGI to fix it's paths to conform to the spec.  A setting
; of zero causes PHP to behave as before.  Default is zero.  You should fix your scripts
; to use SCRIPT_FILENAME rather than PATH_TRANSLATED.
; cgi.fix_pathinfo=0
; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
; security tokens of the calling client.  This allows IIS to define the
; security context that the request runs under.  mod_fastcgi under Apache
; does not currently support this feature (03/17/2002)
; Set to 1 if running under IIS.  Default is zero.
; fastcgi.impersonate = 1;
; cgi.rfc2616_headers configuration option tells PHP what type of headers to
; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
; is supported by Apache. When this option is set to 1 PHP will send
; RFC2616 compliant header.
; Default is zero.
;cgi.rfc2616_headers = 0
; File Uploads ;
; Whether to allow HTTP file uploads.
file_uploads = On
; Temporary directory for HTTP uploaded files (will use system default if not
; specified).
;upload_tmp_dir =
; Maximum allowed size for uploaded files.
upload_max_filesize = 2M
; Fopen wrappers ;
; Whether to allow the treatment of URLs (like http:// or ftp://) as files.
allow_url_fopen = On
; Define the anonymous ftp password (your email address)
;from="[email protected]"
; Define the User-Agent string
; user_agent="PHP"
; Default timeout for socket based streams (seconds)
default_socket_timeout = 60
; If your scripts have to deal with files from Macintosh systems,
; or you are running on a Mac and need to deal with files from
; unix or win32 systems, setting this flag will cause PHP to
; automatically detect the EOL character in those files so that
; fgets() and file() will work regardless of the source of the file.
; auto_detect_line_endings = Off
; Dynamic Extensions ;
; If you wish to have an extension loaded automatically, use the following
; syntax:
;   extension=modulename.extension
; For example, on Windows:
;   extension=msql.dll
; ... or under UNIX:
;   extension=msql.so
; Note that it should be the name of the module only; no directory information
; needs to go here.  Specify the location of the extension with the
; extension_dir directive above.
;Windows Extensions
;Note that MySQL and ODBC support is now built in, so no dll is needed for it.
;extension=php_bz2.dll
;extension=php_cpdf.dll
;extension=php_crack.dll
;extension=php_curl.dll
;extension=php_db.dll
;extension=php_dba.dll
;extension=php_dbase.dll
;extension=php_dbx.dll
;extension=php_domxml.dll
;extension=php_exif.dll
;extension=php_fdf.dll
;extension=php_filepro.dll
;extension=php_gd2.dll
;extension=php_gettext.dll
;extension=php_hyperwave.dll
;extension=php_iconv.dll
;extension=php_ifx.dll
;extension=php_iisfunc.dll
;extension=php_imap.dll
;extension=php_interbase.dll
;extension=php_java.dll
;extension=php_ldap.dll
;extension=php_mbstring.dll
;extension=php_mcrypt.dll
;extension=php_mhash.dll
;extension=php_mime_magic.dll
;extension=php_ming.dll
;extension=php_mssql.dll
;extension=php_msql.dll
;extension=php_oci8.dll
;extension=php_openssl.dll
;extension=php_oracle.dll
;extension=php_pdf.dll
;extension=php_pgsql.dll
;extension=php_printer.dll
;extension=php_shmop.dll
;extension=php_snmp.dll
;extension=php_sockets.dll
;extension=php_sybase_ct.dll
;extension=php_w32api.dll
;extension=php_xmlrpc.dll
;extension=php_xslt.dll
;extension=php_yaz.dll
;extension=php_zip.dll
; Module Settings ;
[Syslog]
; Whether or not to define the various syslog variables (e.g. $LOG_PID,
; $LOG_CRON, etc.).  Turning it off is a good idea performance-wise.  In
; runtime, you can define these variables by calling define_syslog_variables().
;define_syslog_variables  = Off
[mail function]
; For Win32 only.
;SMTP = localhost
smtp_port = 25
; For Win32 only.
;sendmail_from = [email protected]
; For Unix only.  You may supply arguments as well (default: "sendmail -t -i").
sendmail_path = "/usr/sbin/sendmail -t -i"
[Java]
;java.class.path = .\php_java.jar
;java.home = c:\jdk
;java.library = c:\jdk\jre\bin\hotspot\jvm.dll
;java.library.path = .\
[SQL]
sql.safe_mode = Off
[ODBC]
;odbc.default_db    =  Not yet implemented
;odbc.default_user  =  Not yet implemented
;odbc.default_pw    =  Not yet implemented
; Allow or prevent persistent links.
odbc.allow_persistent = On
; Check that a connection is still valid before reuse.
odbc.check_persistent = On
; Maximum number of persistent links.  -1 means no limit.
odbc.max_persistent = -1
; Maximum number of links (persistent + non-persistent).  -1 means no limit.
odbc.max_links = -1
; Handling of LONG fields.  Returns number of bytes to variables.  0 means
; passthru.
odbc.defaultlrl = 4096
; Handling of binary data.  0 means passthru, 1 return as is, 2 convert to char.
; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
; of uodbc.defaultlrl and uodbc.defaultbinmode
odbc.defaultbinmode = 1
[MySQL]
mysql.allow_persistent = On
mysql.max_persistent = -1
mysql.max_links = -1
; Default port number for mysql_connect().  If unset, mysql_connect() will use
; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
; compile-time value defined MYSQL_PORT (in that order).  Win32 will only look
; at MYSQL_PORT.
mysql.default_port =
; Default socket name for local MySQL connects.  If empty, uses the built-in
; MySQL defaults.
mysql.default_socket =
; Default host for mysql_connect() (doesn't apply in safe mode).
mysql.default_host =
; Default user for mysql_connect() (doesn't apply in safe mode).
mysql.default_user =
; Default password for mysql_connect() (doesn't apply in safe mode).
; Note that this is generally a *bad* idea to store passwords in this file.
; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
; and reveal this password!  And of course, any users with read access to this
; file will be able to reveal the password as well.
mysql.default_password =
; Maximum time (in seconds) for connect timeout. -1 means no limit
mysql.connect_timeout = 60
; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
; SQL-Errors will be displayed.
mysql.trace_mode = Off
[mSQL]
msql.allow_persistent = On
msql.max_persistent = -1
; Maximum number of links (persistent+non persistent).  -1 means no limit.
msql.max_links = -1
[PostgresSQL]
pgsql.allow_persistent = On
; Detect broken persistent links always with pg_pconnect(). Need a little overhead.
pgsql.auto_reset_persistent = Off
pgsql.max_persistent = -1
pgsql.max_links = -1
; Ignore PostgreSQL backends Notice message or not.
pgsql.ignore_notice = 0
; Log PostgreSQL backends Noitce message or not.
; Unless pgsql.ignore_notice=0, module cannot log notice message.
pgsql.log_notice = 0
[Sybase]
sybase.allow_persistent = On
sybase.max_persistent = -1
sybase.max_links = -1
;sybase.interface_file = "/usr/sybase/interfaces"
; Minimum error severity to display.
sybase.min_error_severity = 10
; Minimum message severity to display.
sybase.min_message_severity = 10
; Compatability mode with old versions of PHP 3.0.
; If on, this will cause PHP to automatically assign types to results according
; to their Sybase type, instead of treating them all as strings.  This
; compatibility mode will probably not stay around forever, so try applying
; whatever necessary changes to your code, and turn it off.
sybase.compatability_mode = Off
[Sybase-CT]
sybct.allow_persistent = On
sybct.max_persistent = -1
sybct.max_links = -1
; Minimum server message severity to display.
sybct.min_server_severity = 10
; Minimum client message severity to display.
sybct.min_client_severity = 10
[dbx]
; returned column names can be converted for compatibility reasons
; possible values for dbx.colnames_case are
; "unchanged" (default, if not set)
; "lowercase"
; "uppercase"
; the recommended default is either upper- or lowercase, but
; unchanged is currently set for backwards compatibility
dbx.colnames_case = "unchanged"
[bcmath]
; Number of decimal digits for all bcmath functions.
bcmath.scale = 0
[browscap]
;browscap = extra/browscap.ini
[Informix]
; Default host for ifx_connect() (doesn't apply in safe mode).
ifx.default_host =
; Default user for ifx_connect() (doesn't apply in safe mode).
ifx.default_user =
; Default password for ifx_connect() (doesn't apply in safe mode).
ifx.default_password =
ifx.allow_persistent = On
ifx.max_persistent = -1
ifx.max_links = -1
; If on, select statements return the contents of a text blob instead of its id.
ifx.textasvarchar = 0
; If on, select statements return the contents of a byte blob instead of its id.
ifx.byteasvarchar = 0
; Trailing blanks are stripped from fixed-length char columns.  May help the
; life of Informix SE users.
ifx.charasvarchar = 0
; If on, the contents of text and byte blobs are dumped to a file instead of
; keeping them in memory.
ifx.blobinfile = 0
; NULL's are returned as empty strings, unless this is set to 1.  In that case,
; NULL's are returned as string 'NULL'.
ifx.nullformat = 0
[Session]
; Handler used to store/retrieve data.
session.save_handler = files
; Argument passed to save_handler.  In the case of files, this is the path
; where data files are stored. Note: Windows users have to change this
; variable in order to use PHP's session functions.
; As of PHP 4.0.1, you can define the path as: session.save_path = "N;/path"
; where N is an integer.  Instead of storing all the session files in
; /path, what this will do is use subdirectories N-levels deep, and
; store the session data in those directories.  This is useful if you
; or your OS have problems with lots of files in one directory, and is
; a more efficient layout for servers that handle lots of sessions.
; NOTE 1: PHP will not create this directory structure automatically.
;         You can use the script in the ext/session dir for that purpose.
; NOTE 2: See the section on garbage collection below if you choose to
;         use subdirectories for session storage
session.save_path = /tmp
; Whether to use cookies.
session.use_cookies = 1
; This option enables administrators to make their users invulnerable to
; attacks which involve passing session ids in URLs; defaults to 0.
; session.use_only_cookies = 1
; Name of the session (used as cookie name).
session.name = PHPSESSID
; Initialize session on request startup.
session.auto_start = 0
; Lifetime in seconds of cookie or, if 0, until browser is restarted.
session.cookie_lifetime = 0
; The path for which the cookie is valid.
session.cookie_path = /
; The domain for which the cookie is valid.
session.cookie_domain =
; Handler used to serialize data.  php is the standard serializer of PHP.
session.serialize_handler = php
; Define the probability that the 'garbage collection' process is started
; on every session initialization.
; The probability is calculated by using gc_probability/gc_divisor,
; e.g. 1/100 means there is a 1% chance that the GC process starts
; on each request.
session.gc_probability = 1
session.gc_divisor     = 100
; After this number of seconds, stored data will be seen as 'garbage' and
; cleaned up by the garbage collection process.
session.gc_maxlifetime = 1440
; NOTE: If you are using the subdirectory option for storing session files
;       (see session.save_path above), then garbage collection does *not*
;       happen automatically.  You will need to do your own garbage
;       collection through a shell script, cron entry, or some other method.
;       For example, the following script would is the equivalent of
;       setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
;          cd /path/to/sessions; find -cmin +24 | xargs rm
; PHP 4.2 and less have an undocumented feature/bug that allows you to
; to initialize a session variable in the global scope, albeit register_globals
; is disabled.  PHP 4.3 and later will warn you, if this feature is used.
; You can disable the feature and the warning separately. At this time,
; the warning is only displayed, if bug_compat_42 is enabled.
session.bug_compat_42 = 1
session.bug_compat_warn = 1
; Check HTTP Referer to invalidate externally stored URLs containing ids.
; HTTP_REFERER has to contain this substring for the session to be
; considered as valid.
session.referer_check =
; How many bytes to read from the file.
session.entropy_length = 0
; Specified here to create the session id.
session.entropy_file =
;session.entropy_length = 16
;session.entropy_file = /dev/urandom
; Set to {nocache,private,public,} to determine HTTP caching aspects
; or leave this empty to avoid sending anti-caching headers.
session.cache_limiter = nocache
; Document expires after n minutes.
session.cache_expire = 180
; trans sid support is disabled by default.
; Use of trans sid may risk your users security.
; Use this option with caution.
; - User may send URL contains active session ID
;   to other person via. email/irc/etc.
; - URL that contains active session ID may be stored
;   in publically accessible computer.
; - User may access your site with the same session ID
;   always using URL stored in browser's history or bookmarks.
session.use_trans_sid = 0
; The URL rewriter will look for URLs in a defined set of HTML tags.
; form/fieldset are special; if you include them here, the rewriter will
; add a hidden <input> field with the info which is otherwise appended
; to URLs.  If you want XHTML conformity, remove the form entry.
; Note that all valid entries require a "=", even if no value follows.
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=,fieldset="
[MSSQL]
mssql.allow_persistent = On
mssql.max_persistent = -1
mssql.max_links = -1
mssql.min_error_severity = 10
mssql.min_message_severity = 10
mssql.compatability_mode = Off
; Connect timeout
;mssql.connect_timeout = 5
; Query timeout
;mssql.timeout = 60
; Valid range 0 - 2147483647.  Default = 4096.
;mssql.textlimit = 4096
;mssql.textsize = 4096
; Limits the number of records in each batch.  0 = all records in one batch.
;mssql.batchsize = 0
; Specify how datetime and datetim4 columns are returned
; On => Returns data converted to SQL server settings
; Off => Returns values as YYYY-MM-DD hh:mm:ss
;mssql.datetimeconvert = On
; Use NT authentication when connecting to the server
mssql.secure_connection = Off
; Specify max number of processes. Default = 25
;mssql.max_procs = 25
[Assertion]
; Assert(expr); active by default.
;assert.active = On
; Issue a PHP warning for each failed assertion.
;assert.warning = On
; Don't bail out by default.
;assert.bail = Off
; User-function to be called if an assertion fails.
;assert.callback = 0
; Eval the expression with current error_reporting().  Set to true if you want
; error_reporting(0) around the eval().
;assert.quiet_eval = 0
[Ingres II]
ingres.allow_persistent = On
ingres.max_persistent = -1
; Maximum number of links, including persistents.  -1 means no limit.
ingres.max_links = -1
; Default database (format: [node_id::]dbname[/srv_class]).
ingres.default_database =
; Default user.
ingres.default_user =
; Default password.
ingres.default_password =
[Verisign Payflow Pro]
; Default Payflow Pro server.
pfpro.defaulthost = "test-payflow.verisign.com"
; Default port to connect to.
pfpro.defaultport = 443
; Default timeout in seconds.
pfpro.defaulttimeout = 30
; Default proxy IP address (if required).
;pfpro.proxyaddress =
; Default proxy port.
;pfpro.proxyport =
; Default proxy logon.
;pfpro.proxylogon =
; Default proxy password.
;pfpro.proxypassword =
[com]
; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
;com.typelib_file =
; allow Distributed-COM calls
;com.allow_dcom = true
; autoregister constants of a components typlib on com_load()
;com.autoregister_typelib = true
; register constants casesensitive
;com.autoregister_casesensitive = false
; show warnings on duplicate constat registrations
;com.autoregister_verbose = true
[Printer]
;printer.default_printer = ""
[mbstring]
; language for internal character representation.
;mbstring.language = Japanese
; internal/script encoding.
; Some encoding cannot work as internal encoding.
; (e.g. SJIS, BIG5, ISO-2022-*)
;mbstring.internal_encoding = EUC-JP
; http input encoding.
;mbstring.http_input = auto
; http output encoding. mb_output_handler must be
; registered as output buffer to function
;mbstring.http_output = SJIS
; enable automatic encoding translation accoding to
; mbstring.internal_encoding setting. Input chars are
; converted to internal encoding by setting this to On.
; Note: Do _not_ use automatic encoding translation for
;       portable libs/applications.
;mbstring.encoding_translation = Off
; automatic encoding detection order.
; auto means
;mbstring.detect_order = auto
; substitute_character used when character cannot be converted
; one from another
;mbstring.substitute_character = none;
; overload(replace) single byte functions by mbstring functions.
; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
; etc. Possible values are 0,1,2,4 or combination of them.
; For example, 7 for overload everything.
; 0: No overload
; 1: Overload mail() function
; 2: Overload str*() functions
; 4: Overload ereg*() functions
;mbstring.func_overload = 0
[FrontBase]
;fbsql.allow_persistent = On
;fbsql.autocommit = On
;fbsql.default_database =
;fbsql.default_database_password =
;fbsql.default_host =
;fbsql.default_password =
;fbsql.default_user = "_SYSTEM"
;fbsql.generate_warnings = Off
;fbsql.max_connections = 128
;fbsql.max_links = 128
;fbsql.max_persistent = -1
;fbsql.max_results = 128
;fbsql.batchSize = 1000
[Crack]
; Modify the setting below to match the directory location of the cracklib
; dictionary files.  Include the base filename, but not the file extension.
; crack.default_dictionary = "c:\php\lib\cracklib_dict"
[exif]
; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
; With mbstring support this will automatically be converted into the encoding
; given by corresponding encode setting. When empty mbstring.internal_encoding
; is used. For the decode settings you can distinguish between motorola and
; intel byte order. A decode setting cannot be empty.
;exif.encode_unicode = ISO-8859-15
;exif.decode_unicode_motorola = UCS-2BE
;exif.decode_unicode_intel    = UCS-2LE
;exif.encode_jis =
;exif.decode_jis_motorola = JIS
;exif.decode_jis_intel    = JIS
; Local Variables:
; tab-width: 4
; End:
date.timezone = "Europe/Moscow"
zend_extension = "/usr/local/ioncube/ioncube_loader_lin_5.2.so"
zend_extension = "/usr/local/lib/ZendOptimizer_5.2.so"
that's ok
[PHP]
; WARNING ;
; About this file ;
; directive = value
; |        bitwise OR
; &        bitwise AND
; ~        bitwise NOT
; !        boolean NOT
engine = On
short_open_tag = On
asp_tags = Off
precision    =  12
y2k_compliance = On
;       is doing.
;output_handler =
; Safe Mode
;safe_mode = Off
;open_basedir =
disable_classes =
; Misc
expose_php = On
; Resource Limits ;
; reporting level
;                     empty string)
;                     initial startup
; Examples:
display_errors = On
log_errors = On
; sourcelines.
track_errors = Off
;html_errors = Off
; the dot.
;docref_ext = .html
;error_log = syslog
; Data Handling ;
; Default is "&".
; Default is "&".
; variables.
post_max_size = 8M
gpc_order = "GPC"
; Magic quotes
auto_prepend_file =
auto_append_file =
doc_root =
; if nonempty.
user_dir =
; disabled on them.
enable_dl = On
; every request.
; cgi.nph = 1
; Default is zero.
; File Uploads ;
file_uploads = On
; specified).
;upload_tmp_dir =
; Fopen wrappers ;
; user_agent="PHP"
; syntax:
;   extension=msql.so
;Windows Extensions
; Module Settings ;
[Syslog]
[mail function]
; For Win32 only.
;SMTP = localhost
smtp_port = 25
; For Win32 only.
[Java]
;java.home = c:\jdk
[SQL]
sql.safe_mode = Off
[ODBC]
odbc.max_links = -1
; passthru.
[MySQL]
; at MYSQL_PORT.
; MySQL defaults.
[mSQL]
msql.max_links = -1
[PostgresSQL]
[Sybase]
[Sybase-CT]
[dbx]
; "lowercase"
; "uppercase"
[bcmath]
bcmath.scale = 0
[browscap]
[Informix]
ifx.default_host =
ifx.default_user =
ifx.max_links = -1
ifx.blobinfile = 0
ifx.nullformat = 0
[Session]
; on each request.
[MSSQL]
; Connect timeout
; Query timeout
;mssql.timeout = 60
[Assertion]
;assert.active = On
;assert.bail = Off
[Ingres II]
; Default user.
; Default password.
;pfpro.proxyport =
;pfpro.proxylogon =
[com]
;com.typelib_file =
[Printer]
[mbstring]
; auto means
; one from another
; 0: No overload
[FrontBase]
[Crack]
[exif]
;exif.encode_jis =
; Local Variables:
; tab-width: 4
; End:
that's ok thanks you very much:)
Last part of Claimav installation:
ERROR: Please edit the example config file /etc/freshclam.conf
ERROR: Can't open/parse the config file /etc/freshclam.conf
Restarting freshclam.
cat: /var/run/clamd.pid: No such file or directory
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
Starting clamd daemon: /usr/local/sbin/clamd
ERROR: Please edit the example config file /usr/local/etc/clamd.conf
ERROR: Can't open/parse the config file /usr/local/etc/clamd.conf
Starting freshclam daemon: /usr/local/bin/freshclam -d -c 6
Restarting clamd.
Shutting down clamd: [FAILED]
Starting clamd: LibClamAV Error: cli_loaddb(): No supported database files found in /usr/share/clamav
ERROR: Can't open file or directory
[FAILED]
Restarting exim.
Shutting down exim:
Starting exim:
Done ClamAV.
Does this have anything to do with the thread topic, Problem with RAM?
If not, it hould probably be posted in a new thread rather than be re-oppening a thread from eight months ago.
Restarting clamd.
[FAILED]
Restarting exim.
Shutting down exim:
Starting exim:
Done ClamAV.
