Problem with references after update
RosT
I'm update to Apache/2.0.55 and PHP/4.4.0 on FreeBSD 4.11
Some php-scripts don't work with error:
Notice:
Only variables should be assigned by reference
[/home/hfzinew/domains/fei.org.ua/public_html/lib/tools.lib.php:60]
Line 60 of code:
$aArea = &$gSid->fetch(__CFG_SESSION_AREA);
What to do?
read php changelog see if code has been made obselete, if yes fix the code. Or it could be just a setting you need to change in php.ini to enable some compatiblity.
this is due to php 4.4.0 and an issue
with references, much documented
elsewhere.
try changing that line to:
$aArea = $gSid->fetch(__CFG_SESSION_AREA);
see if that fixes. going from 4.3.11 to
4.4.0 has led to many php scripts having
this issue.
