Problem with restore
phpempire
Hello All
I had convert over 4000 Cpanel Backup to Directadmin
I solve very problem but not solve this problem :confused:
when resotre cpanel to da converted backup show error :
Example :
Unable to restore database asalbano_shopp.sql to asalbano_shopp : ERROR 1045 (28000): Access denied for user 'asalbano'@'localhost' (using password: NO)
I very Glad if help me
very Thank u
i wanna fix problem not clean questions
i over 4000 sites and very site have a this error
please help me:confused:
User mr.applesauce is simply saying you should create the databases manually, and then restore the backups manually.
I can understand why you don't want to do it this way.
The problem appears to be that you're trying to restore a database without using a password. I don't know why that's happening.
What steps did you take to create your backup? Did you use the script found on these forums?
