Problem with ServerRoot /etc/httpd
unique2world
Hi
How to fix it?
-- Unit nginx.service has begun starting up.
Sep 07 19:21:06 server.site.com nginx[8164]: nginx: [emerg] unknown directive "ServerRoot" in /usr/local/directadmin/data/users/admin/nginx.conf:16
Sep 07 19:21:06 server.site.com nginx[8164]: nginx: configuration file /etc/nginx/nginx.conf test failed
Sep 07 19:21:06 server.site.com systemd[1]: nginx.service: control process exited, code=exited status=1
Sep 07 19:21:06 server.site.com systemd[1]: Failed to start The nginx HTTP and reverse proxy server.
What's the output of:
grep -r ServerRoot /usr/local/directadmin/data/templates/
You may also have custom code defined in "Customize HTTPd Configuration" on admin level.
output:
/usr/local/directadmin/data/templates/httpd.conf:ServerRoot "/etc/httpd"
No
How to fix it?
I’d suggest opening a support ticket, as it’s most likely custom configuration/customization on the system.
