My Sieve filters doesn't work
My config:
DirectAdmin 1.50.0
Custombuild 2.0.0 (rev: 1528)
dovecot 2.2.22 (fe789d2) with Pidgeonhole SpamAssasin, SpamBlocker and DKIM
Exim 4.86.2
Debian 7.9
# cat /var/www/html/roundcube/plugins/managesieve/config.inc.php
# cat /etc/dovecot/dovecot.conf
# cat /etc/dovecot/conf.d/90-sieve.conf
Example filter added by roundcube:
cat /home/USERNAME/imap/DOMAIN/test/.dovecot.sieve
# ps aux | grep -v grep | grep managesieve-login
# netstat -an | grep LISTEN | grep :4190
Sieve logs were not generated...
# less /var/log/dovecot-lmtp.log
I'm stuck... Any tips?
My config:
DirectAdmin 1.50.0
Exim 4.86.2
Debian 7.9
<?php
// managesieve server port. When empty the port will be determined automatically
// using getservbyname() function, with 4190 as a fallback.
// $config['managesieve_port'] = null;
$config['managesieve_port'] = 4190;
// managesieve server address, default is localhost.
// Replacement variables supported in host name:
// %h - user's IMAP hostname
// %n - http hostname ($_SERVER['SERVER_NAME'])
// %d - domain (http hostname without the first part)
// For example %n = mail.domain.tld, %d = domain.tld
$config['managesieve_host'] = 'localhost';
// authentication method. Can be CRAM-MD5, DIGEST-MD5, PLAIN, LOGIN, EXTERNAL
// or none. Optional, defaults to best method supported by server.
$config['managesieve_auth_type'] = null;
// Optional managesieve authentication identifier to be used as authorization proxy.
// Authenticate as a different user but act on behalf of the logged in user.
// Works with PLAIN and DIGEST-MD5 auth.
$config['managesieve_auth_cid'] = null;
// Optional managesieve authentication password to be used for imap_auth_cid
$config['managesieve_auth_pw'] = null;
// use or not TLS for managesieve server connection
// Note: tls:// prefix in managesieve_host is also supported
$config['managesieve_usetls'] = false;
// Connection scket context options
// See http://php.net/manual/en/context.ssl.php
// The example below enables server certificate validation
//$config['managesieve_conn_options'] = array(
// 'ssl' => array(
// 'verify_peer' => true,
// 'verify_depth' => 3,
// 'cafile' => '/etc/openssl/certs/ca.crt',
$config['managesieve_conn_options'] = null;
// default contents of filters script (eg. default spam filter)
$config['managesieve_default'] = '/etc/dovecot/sieve/global';
// The name of the script which will be used when there's no user script
$config['managesieve_script_name'] = 'managesieve';
// Sieve RFC says that we should use UTF-8 endcoding for mailbox names,
// but some implementations does not covert UTF-8 to modified UTF-7.
// Defaults to UTF7-IMAP
$config['managesieve_mbox_encoding'] = 'UTF-8';
// I need this because my dovecot (with listescape plugin) uses
// ':' delimiter, but creates folders with dot delimiter
$config['managesieve_replace_delimiter'] = '';
// disabled sieve extensions (body, copy, date, editheader, encoded-character,
// envelope, environment, ereject, fileinto, ihave, imap4flags, index,
// mailbox, mboxmetadata, regex, reject, relational, servermetadata,
// spamtest, spamtestplus, subaddress, vacation, variables, virustest, etc.
// Note: not all extensions are implemented
$config['managesieve_disabled_extensions'] = array();
// Enables debugging of conversation with sieve server. Logs it into <log_dir>/sieve
$config['managesieve_debug'] = false;
// Enables features described in http://wiki.kolab.org/KEP:14
$config['managesieve_kolab_master'] = false;
// Script name extension used for scripts including. Dovecot uses '.sieve',
// Cyrus uses '.siv'. Doesn't matter if you have managesieve_kolab_master disabled.
$config['managesieve_filename_extension'] = '.sieve';
// List of reserved script names (without extension).
// Scripts listed here will be not presented to the user.
$config['managesieve_filename_exceptions'] = array();
// List of domains limiting destination emails in redirect action
// If not empty, user will need to select domain from a list
$config['managesieve_domains'] = array();
// Enables separate management interface for vacation responses (out-of-office)
// 0 - no separate section (default),
// 1 - add Vacation section,
// 2 - add Vacation section, but hide Filters section
$config['managesieve_vacation'] = 0;
// Default vacation interval (in days).
// Note: If server supports vacation-seconds extension it is possible
// to define interval in seconds here (as a string), e.g. "3600s".
$config['managesieve_vacation_interval'] = 0;
// Some servers require vacation :addresses to be filled with all
// user addresses (aliases). This option enables automatic filling
// of these on initial vacation form creation.
$config['managesieve_vacation_addresses_init'] = false;
// Supported methods of notify extension. Default: 'mailto'
$config['managesieve_notify_methods'] = array('mailto');
## Dovecot 2.0 configuration file
!include conf/ip.conf
auth_username_chars = abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890.-_@&
auth_verbose = yes
disable_plaintext_auth = no
login_greeting = Dovecot DA ready.
mail_access_groups = mail
default_login_user = dovecot
mail_location = maildir:~/Maildir
!include conf/limits.conf
passdb {
driver = shadow
passdb {
args = username_format=%n /etc/virtual/%d/passwd
driver = passwd-file
!include conf/protocols.conf
!include conf/mail_plugins.conf
service auth {
user = root
service imap-login {
process_min_avail = 16
user = dovecot
service pop3-login {
user = dovecot
!include conf/ssl.conf
userdb {
driver = passwd
userdb {
verbose_proctitle = yes
protocol imap {
!include conf/imap_mail_plugins.conf
protocol pop3 {
pop3_uidl_format = %08Xu%08Xv
pop3_logout_format = top=%t/%p, retr=%r/%b, del=%d/%m, size=%s, bytes=%i/%o
!include conf/mail_max_userip_connections.conf
!include_try conf/lmtp.conf
!include conf.d/*.conf
#add sieve to end of line in:
#/etc/dovecot/conf/protocols.conf, eg:
#protocols = imap pop3 lmtp sieve
#Managesieve service (allows rules editing on client-side)
service managesieve-login {
inet_listener sieve {
port = 4190
service_count = 1
process_min_avail = 4
vsz_limit = 64M
service managesieve {
protocol sieve {
managesieve_max_line_length = 65536
managesieve_implementation_string = Dovecot Pigeonhole
managesieve_max_compile_errors = 5
managesieve_logout_format = bytes=%i/%o
log_path = /var/log/dovecot-sieve-errors.log
info_log_path = /var/log/dovecot-sieve.log
plugin {
#More details: http://wiki2.dovecot.org/Pigeonhole/Sieve/Configuration
# The location of the user's main script storage. The active script
# in this storage is used as the main user script executed during
# delivery. The include extension fetches the :personal scripts
# from this location. When ManageSieve is used, this is also where
# scripts are uploaded. This example uses the file system as
# storage, with all the user's scripts located in the directory
# `~/sieve' and the active script (symbolic link) located at
# `~/.dovecot.sieve'.
sieve = file:~/sieve;active=~/.dovecot.sieve
# If the user has no personal active script (i.e. if the location
# indicated in sieve= does not exist or has no active script), use
# this one:
sieve_default = /var/lib/dovecot/sieve/default.sieve
# The include extension fetches the :global scripts from this
# location.
sieve_global = /var/lib/dovecot/sieve/global/
require ["fileinto"];
# rule:[test]
if true
fileinto "INBOX.spam";
dovecot 13934 0.0 0.0 27480 2968 ? S 23:18 0:00 dovecot/managesieve-login
dovecot 17530 0.0 0.0 27480 2964 ? S 23:29 0:00 dovecot/managesieve-login
dovecot 18618 0.0 0.0 27480 2964 ? S 23:36 0:00 dovecot/managesieve-login
dovecot 18631 0.0 0.0 27480 2968 ? S 23:36 0:00 dovecot/managesieve-login
tcp 0 0 0.0.0.0:4190 0.0.0.0:* LISTEN
# less /var/log/dovecot-sieve-errors.log
/var/log/dovecot-sieve-errors.log: No such file or directory
# less /var/log/dovecot-sieve.log
/var/log/dovecot-sieve.log: No such file or directory
Mar 22 23:17:22 lmtp(10023): Info: Connect from local
Mar 22 23:17:22 lmtp(test@DOMAIN): Info: d96iJ/nC8VYnJwAA13kxwg: msgid=<[email protected]>: saved mail to INBOX
Mar 22 23:17:22 lmtp(10023): Info: Disconnect from local: Successful quit
