Yes, there is. It might already be there though, have a look in the headers of an e-mail sent by PHP and search for X-PHP-SCRIPT.
If you use customapache, open build and look for APPLY_MAIL_HEADER_PATCH. Make sure it's set to 1 as follows:
APPLY_MAIL_HEADER_PATCH=1
If you use custombuild, open options.conf and look for mail-header-patch. Make sure it's set to yes as follows:
mail-header-patch=yes
Rebuild PHP afterwards and restart Apache.
./build clean
./build php n
/sbin/service httpd restart
E-mails sent by PHP now have the following header:
X-PHP-Script: domain.com/folder/script.php for 123.123.123.123
how about the server that install manually without use custombuild or customapache ?? how to trace the spammer ?? also, how to secure smtp port or other sendmail, because i got report from many provider that my server have been use to spam, when i check nothing suspicious ....
