Problem with SSL after adding ip6
grandm1961
Wijhe
Hello, I asked my provider to point my ip6 to my hostname as they did with ip4.
I then put all the dns files for ip6 in direct admin and Cloudflare.
the main domain end with .eu and I have a pointer for the .nl to the .eu
that all worked fine until I added the ip6 to the ip manager and joined them to each other
I than rebuild everything and wanted a new ssl certificate for the .eu and .nl , and now it only creates a new ssl certificate for the .nl alone and gives a error for the .eu domain name.
Setting up certificate for a hostname: server.duraweb.eu
server.duraweb.eu was skipped due to unreachable http://server.duraweb.eu/.well-known/acme-challenge/letsencrypt_62af794a59b7fd3f3adfd96f79c7fd40 file.
mail.duraweb.eu was skipped due to unreachable http://mail.duraweb.eu/.well-known/acme-challenge/letsencrypt_babd7c30c963d67c8448922de80c758f file.
smtp.duraweb.eu was skipped due to unreachable http://smtp.duraweb.eu/.well-known/acme-challenge/letsencrypt_bb21eea88bdcb1cbcd0d5467f289bc4f file.
pop.duraweb.eu was skipped due to unreachable http://pop.duraweb.eu/.well-known/acme-challenge/letsencrypt_84495d77aeacac779a7bb0fcb258acaf file.
imap.duraweb.eu was skipped due to unreachable http://imap.duraweb.eu/.well-known/acme-challenge/letsencrypt_fce7f47985930acc857624ffe58ccd4a file.
ftp.duraweb.eu was skipped due to unreachable http://ftp.duraweb.eu/.well-known/acme-challenge/letsencrypt_03c7addfffec4f067d7375bfca053acf file.
mta-sts.duraweb.eu was skipped due to unreachable http://mta-sts.duraweb.eu/.well-known/acme-challenge/letsencrypt_f257cd32d93709be9b48d26c5620d326 file.
www.duraweb.eu was skipped due to unreachable http://www.duraweb.eu/.well-known/acme-challenge/letsencrypt_b394c8c47e1e6456cbe3691ec412a87f file.
duraweb.eu was skipped due to unreachable http://duraweb.eu/.well-known/acme-challenge/letsencrypt_a2094127f20b3424bf4562804eaf79ed file.
server.duraweb.eu was skipped due to unreachable http://server.duraweb.eu/.well-known/acme-challenge/letsencrypt_7551ef358a3b97d9119297f843451a77 file.
No domains pointing to this server to generate the certificate for.
so if I try to go to the direct admin control panel it says the wrong ssl certificate and showing only the .nl certificate.
What is wrong here?
what to do?
apperantly the ip6 was in my hosts file
And why shouldn't it be? It's also in my host file. Are you running on a LAN? If not, it should be in your hosts file.
Also, be aware that link link the ipv6 to the ipv4 and not the other way around. So click the ipv4 and then select the ipv6 to link to it. Ofcourse before that add the ipv6 to your ip manager.
It is on lan so that's why I had to delete it and now it works, but I get a timeout on the ssllabs.com for the ip6
