Problem with SSL removal and adding a new SSL Cert
SupermanInNY
I have a user who wants to have a 'clean slate' for his SSL certificate.
He had a certificate running fine for a year.
He then messed things up by trying to install the certificate (renewal) on his own and it failed.
Now he wants me to install a new certificate for him.
I tried to clean up his actions (very carefully):
1. I created a directory called: /usr/local/directadmin/data/users/username/domains/old
2. I moved:
somedomainname.com.cacert
somedomainname.com.cert
somedomainname.com.key
to the old/ directory
3. I entered the
Modify Domain (domain administration):
Modify somedomainname.com
Secure SSL (Ignored if not allowed)
UnChecked the Secure SSL (Ignored if not allowed) and then restarted Apache.
So far, it went well.
I then proceeded to start a 'clean slate' install of a new certificate.
But, I did it in several steps.
I enabled (Checked) the the Secure SSL (Ignored if not allowed) and restarted Apache.
It failed!
# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: Syntax error on line 51 of /usr/local/directadmin/data/users/username/httpd.conf:
SSLCertificateFile: file '/usr/local/directadmin/data/users/username/domains/somedomainname.com.cert' does not exist or is empty
Why did it populate the httpd.conf with the 'old values' of the SSL?
Where does it store the knowledge that I had a certificate installed once?
In this particular instance, I don't want it to 'remember' that there was a previous SSL installed. I want to have a clean slate.
Please advise on where to look for the 'memory' effect.
thanks,
-Alon.
[RESOLVED]
From John of DA:
Login to DA as user soragit.
Go to the SSL Management.
For a "Clean Slate" set him to use the shared server certificate (top option).
If you move the cert/key files out of the way and don't change what files apache is using, then the apache restart will fail.
that resolved the problem.
I then proceeded to Delete the values that were still populating the big text box of the key and cert of the old values and indeed clean slate :)
thanks Jeff :).
-Alon.
