problem with webmail
agressor
hi guys, i have a big problem with webmail
have this output when i try to login mysite.tld/webmail
ERROR (512): Smarty error: problem creating directory "./tmp/_cached_templates" (/webmail/smarty/Smarty.class.php:589)
So my ask is this: Can i get working it, without disable safe_mode in main php.ini (/usr/local/lib/php.ini)???
any hint is welcome.
thanks.
Francisco.-
PHP as CGI? If yes, try:
chown -R webapps:webapps /var/www/html
I know this is an old topic but the problem popped up again.
Just made a new fresh install with Centos 5.7-x64 and custombuild 1.2x php5 in cli.
Did the chown on both directories and still getting this same errors
You don't use PHP-CGI, so you should chown it not to webapps:webapps, but apache:apache.
p.s. of course if you aren't using mod_ruid
