Problems accessing DirectAdmin
styl0
Ok...Well basically what my problem is, is I'm the only administrator (out of 2 of us) who can't access direct admin. When I load up http://mybox.name:2222/ it gives me a blankwhite screen without even trying. And on other occasions it gives me a "Connection refused" error, anyone know what's up with it?
It is likely that you're blocked by a firewall. Make sure Port 2222 is open in your network table (you might want to call your ISP). If the Port is open, stop or deactivate your firewall for a short period of time and see if that helps.
My home connection isn't firewalled. I was able to access it up until a few days ago, and right now it's loading the page, BUT it's a blank white screen, that's it.
You had too many invalid logins.
Remove your ip address from the file /usr/local/directadmin/data/admin/ip_blacklist
