Problems Directadmin
staff
France
Hello I have a problem with DirectAdmin when I log in as "admin" :
I run the command ./DirectAdmin b2000
Results :
Bind Error: Make sure there aren't any copies running in the background
Address already in use
If DirectAdmin is running, but you cannot connect to port 2222, check this guide:
I look at the port 2222 is not blocked my license is good
tank you
I just find I add in php.ini
extension= /usr/lib/php5/20090626/IcePHP.so
ice.slice= -I/usr/share/Ice-3.3.1/slice /home/staff76620/murmur/Murmur.ice
and so when I removed his work but keep this in php.ini
