In installation I've found little bugs:
For RedHat 9 in install there are displayed services9.tar.gz but its services90.tar.gz
When i try to install php with the DA Script, i've a problem with Curl, when it compile the last version, the installation never finish (bucle). So I've change the version to an older curl, but there's an install problem... I will install php manually or without curl!
