Problems installing da on fc3
m.degroot
I had a directadmin for a freebsd server, but i let have let it changed to a fc3 license.
This is the output:
10:50:50 (77.90 KB/s) - `/usr/local/directadmin/update.tar.gz' saved [2,567,918/2,567,918]
cat: /etc/rc.conf: No such file or directory
./doChecks.sh: line 20: [: !=: unary operator expected
*** bison is required for compiling, please install bison ***
*** You have /var partition.  The emails and logs will use this partition. *MAKE SURE* its adequately large (6 gig or larger)
Press ctrl-c in the next 3 seconds if you need to stop
Installation didn't pass, halting install.
[root@* ~]# bison --version
bison (GNU Bison) 1.875c
Written by Robert Corbett and Richard Stallman.
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Did I get the FreeBSD version of directadmin?
Or is that error with rc.conf normal? (I know no linux systems with rc.conf).
If anyone have any ideas, please!
Thanks.
You license Must report the same Operating System as you are actually running. If your Server has FreeBSD your licence must be FreeBSD and of the appropriate version, nothing else ;)
