Problems installing DirectAdmin
Wouter
The Netherlands
When I want to install DirectAdmin, I get:
beginning pre-checks, please wait...
adding gd ...
Fetching http://files.directadmin.com/services/packages-5.3-release/Latest/gd.tbz... Done.
pkg_add: package 'gd-2.0.25,1' or its older version already installed
--20:26:42-- https://www.directadmin.com/cgi-bin/daupdate?uid=2118&lid=7908
=> `/usr/local/directadmin/update.tar.gz'
Resolving www.directadmin.com... 66.51.122.131
Connecting to www.directadmin.com|66.51.122.131|:443... connected.
ERROR: Certificate verification error for www.directadmin.com: unable to get local issuer certificate
To connect to www.directadmin.com insecurely, use `--no-check-certificate'.
Unable to establish SSL connection.
tar: Error opening archive: Empty input file: Inappropriate file type or format
Cannot find the DirectAdmin binary. Extraction failed
I can use the "--no-check-certificate" but I don't think this is what we want...
I've got an answer from John:
If you are using freebsd 4.8, try using this version of wget instead:
http://files.directadmin.com/services/freebsd4.8/wget
If that solves your problem, maybe post it in your thread on the forum.
After that I have sent this reply to John:
Hello John,
I’m using FreeBSD 5.4 so that isn’t the problem, but you give me an idea what it could be.
I have installed wget by myself using the ports (/usr/ports/ftp/wget).
That version was conflicting with the DA-install. A “make deinstall” in /usr/ports/ftp/wget and restarting the DA-setup was the solution J.
I will post this also in the thread. Thanks for your support.
