Codefighter
- Oct 21, 2004
I am trying to install an ssl certificate on one of my domains of my dedicated server. I have done this once before on the same machine with the same issuer (StartSSL) but with a different user, domain, and IP.
I have generated the CSR, given it to StartSSL (or GeoTrust?), and they responded back with the Key, which I then pasted under the "-----END RSA PRIVATE KEY-----" area of the "Paste a pre-generated certificate and key" field.
However, I get the following error every time: "Certificate is Invalid"
I also tried installing the CA Root key, which I found on Starterssl.com (that was a shot in the dark).
I tried pasting the certificate exactly as I received it. Then I tried with blank lines here and there, and other variations.
I then re-issued the certificate a second time, watching all instructions carefully, and again a third time.
The domain has a static IP address.
Just for the hexk of it, I generated my own certificate, and all worked fine. Tried StartSSL setup again, same 'certificate is invalid' message from DA.
No matter what I do, I get 'Certificate is Invalid' from DA when using the certificates from StartSSL.
The only difference I se between then and now, is that the common named for my first successful domain was secure.site.com, and this time around I chose www.site.com. Could the subdomain name be a problem?
PS: Read through Jeff Lasman's tutorial, an only difference I noted was secure. vs www. and the use of Comodo vs. StarterSSL.
