Hey guys,
I'm having some problems with custombuild. Everytime I run ./build apache or ./build all, apache doesn't build.
The build propably fails because of this:
Here is the whole log if you need it: https://dl.dropboxusercontent.com/u/30705130/problems.txt
I hope someone can fix this problem
- Gerben
Restarting apache.
Stopping httpd: [FAILED]
Starting httpd: env: /usr/sbin/httpd: No such file or directory
libtool: install: warning: relinking `libaprutil-1.la'
libtool: install: (cd /usr/local/directadmin/custombuild/httpd-2.4.10/srclib/apr-util; /bin/sh /usr/local/directadmin/custombuild/httpd-2.4.10/srclib/apr/libtool --silent --mode=relink gcc -g -O2 -pthread -DHAVE_CONFIG_H -DLINUX -D_REENTRANT -D_GNU_SOURCE -I/usr/local/directadmin/custombuild/httpd-2.4.10/srclib/apr-util/include -I/usr/local/directadmin/custombuild/httpd-2.4.10/srclib/apr-util/include/private -I/usr/local/directadmin/custombuild/httpd-2.4.10/srclib/apr/include -version-info 5:4:5 -o libaprutil-1.la -rpath /etc/httpd/lib buckets/apr_brigade.lo buckets/apr_buckets.lo buckets/apr_buckets_alloc.lo buckets/apr_buckets_eos.lo buckets/apr_buckets_file.lo buckets/apr_buckets_flush.lo buckets/apr_buckets_heap.lo buckets/apr_buckets_mmap.lo buckets/apr_buckets_pipe.lo buckets/apr_buckets_pool.lo buckets/apr_buckets_refcount.lo buckets/apr_buckets_simple.lo buckets/apr_buckets_socket.lo crypto/apr_crypto.lo crypto/apr_md4.lo crypto/apr_md5.lo crypto/apr_passwd.lo crypto/apr_sha1.lo crypto/crypt_blowfish.lo crypto/getuuid.lo crypto/uuid.lo dbd/apr_dbd.lo dbm/apr_dbm.lo dbm/apr_dbm_sdbm.lo dbm/sdbm/sdbm.lo dbm/sdbm/sdbm_hash.lo dbm/sdbm/sdbm_lock.lo dbm/sdbm/sdbm_pair.lo encoding/apr_base64.lo hooks/apr_hooks.lo ldap/apr_ldap_stub.lo ldap/apr_ldap_url.lo memcache/apr_memcache.lo misc/apr_date.lo misc/apr_queue.lo misc/apr_reslist.lo misc/apr_rmm.lo misc/apr_thread_pool.lo misc/apu_dso.lo misc/apu_version.lo strmatch/apr_strmatch.lo uri/apr_uri.lo xlate/xlate.lo xml/apr_xml.lo -lrt -lcrypt -lpthread -lexpat -liconv /usr/local/directadmin/custombuild/httpd-2.4.10/srclib/apr/libapr-1.la -lrt -lcrypt -lpthread )
/usr/bin/ld: /usr/local/lib/libexpat.a(xmlparse.o): relocation R_X86_64_32S against `.text' can not be used when making a shared object; recompile with -fPIC
/usr/local/lib/libexpat.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
libtool: install: error: relink `libaprutil-1.la' with the above command before installing it
make[2]: *** [install] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.10/srclib/apr-util'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.10/srclib'
make: *** [install-recursive] Error 1
- Gerben
