Problems when there are attachments with squirrelmail
ronbell
Brisbane Australia
Something strange with squirrelmail
It all apears fine with normal emails, tested it extensivly.. HOWEVER, if i send an attachment ( exact attachment enclosed for reference )
thats when the problems start.
This is what i do .. step by step
login to squirrel mail
click on inbox
click on subject of received email ( email then opens )
scroll to bottom and click on view attachemnt ( this case a jpg )
i get the image on the screen - so far so good.
re-click back on inbox
relick back on subject of received email ( want to re-open it ) and.....
Fatal error: Call to a member function on a non-object in /var/www/html/squirrelmail-1.4.5/src/read_body.php on line 431
This only happens if there are attachments.
Did a search on the forum can't seem to find anything.
Any ideas ?
Ron
** 31 Jan 2006 **
Hi guys Ron Here again , I have a solution to this.
http://cvs.sf.net/viewcvs.py/squirrelmail/squirrelmail/src/download.php?r1=1.107.2.8&r2=1.107.2.10
THanks to the guys at squirrelmail, This fix took about 10 seconds to put in and it's a known bug !
Anyway all fixed. Ron is a happy chappy..!
After hunting around with google, it might be an issue with php.. there were no concrete solutions, but one suggestion is to go back to php 4.3.11.
http://comments.gmane.org/gmane.mail.squirrelmail.user/22464
perl -pi -e 's/4.4.2/4.3.11/' build
./build update_data
./build clean
./build php n
You might also try to convert to Doveot if wu-imap might be the cause.
http://www.directadmin.com/features.php?id=590
Also, there is /webmail which may act differently. Just something else to test.
