Problems with DA (ip Problems)
snaaps
Netherlands
Main IP give a status error!
Hello I have some problems with DA.
1 when I go to IP Management then he display a error by my first IP (status error)
This is the main ip off my server and its ussing by 43 accounts!
(shared IP)
2 When I log in as a reseller and I create a new account I get this:
Unable to Create User
Details
A valid IP was not provided
3 when I create a reseller I get this message:
Can't open file /etc/virtual/domainowners for reading
Error Creating Domain
then I recieved a mail with the login and said this:
To log in immediately, follow this link, using your username and password:
http://shared:2222
(this is not right!, it most be: http://IP:2222)
4 when i go to /usr/local/directadmin/data/admin/ips there is only one IP this is the second IP off my server. !
Picture off the problem:
I,am just thinking:
when I go to: /usr/local/directadmin/data/admin/ips/
there is only one IP.
the main IP isnt there!
Maby this is the problem?
proberly I make a file like 193.138.204.112 ?
Yes, create a /usr/local/directadmin/data/admin/ips/193.138.204.112 file, with the following
netmask=255.255.255.0
ns=
reseller=
status=server
value=0
Thanks Its works now!
But there is also a other problem that stills there.
when I create a reseller or a account I get this:
Details
Unix User created successfully
User's data directory created successfully
Domains directory created successfully
Domains directory created successfully in user's home
User's System Quotas set
whats does this means?
when I run a nameserver check for this domain everthink is ok.
I have checked the /etc/virtual/ directory and there is file or directory like domainowners
Yesterday A have a problem with the server and rebuild the software on this server. sinds then I have this problem!
