I have problem with my DA Server which around 5 minutes ago, i got kernel panic:
root@mars:~#
Message from syslogd@mars at Wed May 20 10:00:01 2009 ...
mars kernel: [43214030.930000] Oops: 0000 [#1]
mars kernel: [43214030.930000] SMP
mars kernel: [43214030.930000] CPU: 1
mars kernel: [43214030.930000] EIP is at __ext3_get_inode_loc+0x37/0x330 [ext3]
mars kernel: [43214030.930000] eax: f202d154 ebx: 00000000 ecx: 00000001 edx: 00000000
mars kernel: [43214030.930000] esi: dbb2a810 edi: cf3abf14 ebp: a5740fd9 esp: cf3abe94
mars kernel: [43214030.930000] ds: 007b es: 007b ss: 0068
mars kernel: [43214030.930000] Process dataskq (pid: 7299, threadinfo=cf3aa000 task=f78f3a90)
mars kernel: [43214030.930000] Stack: 00000000 dbb2a810 dfeea000 00000003 dfeea078 00000000 dfeea000 d4fe00c0
This is what the /var/log/messages showed:
May 20 09:59:38 mars kernel: [43214007.410000] tcp-pkts-in: IN=eth1 OUT= MAC=00:13:d3:cb:fb:32:00:0f:ea:5c:92:50:08:00 SRC=63.111.24.129 DST=202.162.205.233 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=11759 PROTO=TCP SPT=80 DPT=29237 WINDOW=25596 RES=0x00 ACK URGP=0
May 20 09:59:54 mars kernel: [43214023.150000] EXT3-fs warning (device dm-0): ext3_unlink: Deleting nonexistent file (73105416), 0
May 20 10:00:01 mars kernel: [43214030.930000] f8951f67
May 20 10:00:01 mars kernel: [43214030.930000] Modules linked in: iptable_nat ip_nat ip_conntrack nfnetlink quota_v2 ipv6 dm_mod md_mod tsdev lp r1000 r8169 sg psmouse parport_pc parport shpchp serio_raw ati_agp agpgart i2c_ali1535 i2c_ali15x3 evdev pcspkr pci_hotplug i2c_core ipt_LOG ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables ext3 jbd ehci_hcd ohci_hcd ide_generic usbcore sd_mod sata_uli libata scsi_mod generic alim15x3 thermal processor fan fbcon tileblit font bitblit softcursor vesafb capability commoncap
May 20 10:00:01 mars kernel: [43214030.930000] EIP: 0060:[pg0+944467815/1068905472] Not tainted VLI
May 20 10:00:01 mars kernel: [43214030.930000] EFLAGS: 00010297 (2.6.17-12-server #2)
May 20 10:00:01 mars kernel: [43214030.930000] BUG: warning at kernel/exit.c:855/do_exit()
May 20 10:00:01 mars kernel: [43214030.930000] <c0124ee2> do_exit+0x6c2/0x840 <c01f3289> vgacon_set_cursor_size+0x39/0x120
May 20 10:00:01 mars kernel: [43214030.930000] <c01221fb> printk+0x1b/0x20 <c01045c1> die+0x301/0x310
May 20 10:00:01 mars kernel: [43214030.930000] <c02da64f> do_page_fault+0x28f/0x7a0 <c017a40a> __link_path_walk+0xb6a/0xf20
May 20 10:00:01 mars kernel: [43214030.930000] <c0182318> __d_lookup+0x88/0x110 <c02da3c0> do_page_fault+0x0/0x7a0
May 20 10:00:01 mars kernel: [43214030.930000] <c0103b73> error_code+0x4f/0x54 <f8951f67> __ext3_get_inode_loc+0x37/0x330 [ext3]
May 20 10:00:01 mars kernel: [43214030.930000] <f89522ac> ext3_reserve_inode_write+0x2c/0xa0 [ext3] <f89599ac> ext3_orphan_del+0xbc/0x1f0 [ext3]
May 20 10:00:01 mars kernel: [43214030.930000] <f89143d7> journal_start+0xd7/0x100 [jbd] <c0194537> inotify_inode_is_dead+0x17/0x80
May 20 10:00:01 mars kernel: [43214030.940000] <f8954c91> ext3_delete_inode+0x61/0xd0 [ext3] <f8954c30> ext3_delete_inode+0x0/0xd0 [ext3]
May 20 10:00:01 mars kernel: [43214030.940000] <c018404f> generic_delete_inode+0x7f/0x130 <c0183a1c> iput+0x5c/0x70
May 20 10:00:01 mars kernel: [43214030.940000] <c017b0cf> do_unlinkat+0xef/0x150 <c016b137> __fput+0x117/0x180
May 20 10:00:01 mars kernel: [43214030.940000] <c0130bc8> sys_setresuid+0x198/0x200 <c0102ffb> syscall_call+0x7/0xb
May 20 10:07:02 mars syslogd 1.4.1#18ubuntu6: restart.
May 20 10:07:02 mars kernel: Inspecting /boot/System.map-2.6.17-12-server
May 20 10:07:02 mars kernel: Loaded 22866 symbols from /boot/System.map-2.6.17-12-server.
May 20 10:07:02 mars kernel: Symbols match kernel version 2.6.17.
May 20 10:07:02 mars kernel: No module symbols loaded - kernel modules not enabled.
Do you have any clue what happened?
I cant ssh, everything locked down except the ping.
regards,
decke
root@mars:~#
regards,
decke
