Problems with named and httpd
Dortseboer
I have a server with DA and everytime stopped my named or httpd. I have view the logs but there is no information.
Can somebody tell me where I can look for more details or maybe a solution for fix.
Dortseboer
Ik have transfer the the files and domains to a another server. Now the problem is the named. Everytime the named shutdown in 4 till 5 hours after reboot.
Nov 13 10:36:55 web01 named[31851]: client 94.75.205.158#46887: query (cache) '****/NS/IN' denied
Nov 13 10:37:07 web01 named[31851]: client 94.75.205.158#34763: query (cache) '****/NS/IN' denied
Nov 13 10:44:23 web01 named[31851]: client 62.213.200.116#21034: query (cache) '****/MX/IN' denied
Nov 13 10:44:23 web01 named[31851]: client 62.213.200.116#17591: query (cache) '****/MX/IN' denied
Nov 13 10:54:24 web01 named[31851]: client 62.213.200.116#29522: query (cache) '****/MX/IN' denied
Nov 13 10:54:24 web01 named[31851]: client 62.213.200.116#33221: query (cache) '****/MX/IN' denied
Nov 13 11:04:26 web01 named[31851]: client 62.213.200.116#56037: query (cache) '****/MX/IN' denied
Nov 13 11:04:26 web01 named[31851]: client 62.213.200.116#8187: query (cache) '****/MX/IN' denied
Nov 13 11:11:48 web01 named[31851]: shutting down
Nov 13 11:11:48 web01 named[31851]: stopping command channel on 127.0.0.1#953
Nov 13 11:11:48 web01 named[31851]: no longer listening on 127.0.0.1#53
I have replace the domains in ****
That's odd, it's not telling us what triggered the shutdown. My only guess is perhaps an external trigger.
Check your named.conf.
Compare the stop section (before each domain was added) to this file:
http://www.directadmin.com/named.conf
If you're running FreeBSD:
http://www.directadmin.com/named.conf.freebsd
If yours is different, make a backup of yours, and then try using one of ours.
Ensure you just replace the top section and leave all of the zone files for your domains in place.
Also check:
/var/log/directadmin/system.log
to see if there is anything in DA happening at the time they shutdown.
Lastly, check /var/log/cron as well for any apache/named specific commands.
In the both files there are no errors or think specify on named
Do you have other idea's
