Problems with php.ini
ukhostingdeals
I had a question from a customer of mine today and I am a bit stuck as I am new to all this. My customer said:
I have uploaded my site and I get
FATAL ERROR: register_globals is disabled in php.ini, please enable it!
I have a php.ini file installed in both the public_html and Admin folders
this states
register_globals = 1
How do I fix this?
Check his .htaccess file in public_html if you run PHP as mod_php. You can try adding "php_value register_globals On" to it.
Also see what exactly he's uploading. No scripts from the past few years should be using Register Globals, so he's either using bad practices or an old script with possible exploits.
