Spyder01
I have an user that uses an SSL certificate, it works like a charm but sometimes (when you change his package or update an extra IP) the whole SSL virtualhost has gone. That will result in a "Apache is function normaly" page when you use SSL.
Even rebuilding the config (./build rewrite_confs) isn`t working so there has to be something wrong elsewhere. The problem is that I have no clue at the moment because every other non SSL domains are working well.
Does anyone have a clue / suggestions to check?
