Problems with using W3c Validation
BlackThorn
Istanbul
I'm trying to validate any of our websites on W3c Validator and getting this errors called:
IO Error: www.example.com: Name or service not known.
And I got the following unexpected response when trying to retrieve <https://www.example.com/>:
403 Forbidden
I don't know what is causing this error. W3c explains here: https://validator.w3.org/feed/docs/error/IOError.html but websites are all working fine. What could be problem? I would appreciate it greatly if you could help me. Meanwhile we have a dedicated server that up and running, and it contains a lot of websites. Also, we're using Nginx as the web server.
Would be cool tho, but i think he hided his real domain (hope so at least) but maybe he uses something like CpGuard that blocks a lot of these things.
When people hide their domain it makes it more difficult to help. Most people want to advertise their domain not hide it. That is silly.
I don't think www.example.com is your domain.
Well, you are right about that. It was just an example because I just didn't want to share, that's all. Anyway here's the address of a website: https://validator.w3.org/check?uri=...(detect+automatically)&doctype=Inline&group=0
Yeah it's true, I just didn't want to share as I said. You know, some people may not want to share their websites due to personal reasons. We don't use it or any plugin/software of security by the way.
Either W3 was down or your website was blocking it
I really don't know what caused it out of nowhere. Otherwise there were no problems until last week. We've updated DA from v1.659 to v1.660 right now, but problem still exist.
@floyd @Richard G @ericosman problem solved.
I was blocking aggressive/attacker bots as follows:
if ($http_user_agent ~ (libwww|libwww-perl|Wget|BLEXBot|Baiduspider))
    return 403;
In this specific case, I got the error here as I said. So the whole site cannot be accessed by W3c. After more trouble shooting I found out my issue was that I was block the wrong ones.
To solve:
Remove libwww and libwww-perl strings from the list.
I mean, it-it's like this:
if ($http_user_agent ~ (Wget|BLEXBot|Baiduspider))
    return 403;
That's all. Meanwhile I learned one more thing thanks to this. If you identify libwww, libwww-perl and curl, it means W3c and Let's Encrypt will be blocked from accessing your website.
