problems
SeLLeRoNe
Super Moderator
A Coruña, Spain
i've some problem with directadmin...
When i upload files by file manager he sayd is ok but no one files is uploaded.
When i make backup he say that i receive an email when finished but i dont receive.
When i see mail with webmail and in that mail there is an URL, if i click on i got http:// two times in the URL in new page..
Thanks a lot
no one can help me?
Generally when no one responds it's because no one knows the answer. In such cases you might want to try contacting DA support.
It appears you have three separate issues:
How do you know? Do you check through a shell login? Do you check the DA log at /var/log/directadmin to see if any problems are logged?
Do you check your /var/log/exim/mainlog to see if had a problem delivering the email?
I'm not sure what you mean. Do you mean that if you see a URL and you want to click on it you have to click on it twice? If so, that sounds more like a browser issue than anything else.
hi, thank you for your reply.
I know my english is not so good :)
So, the first issue has been solved, problem was in /homt/tmp directory that desnt exist.
The second one i'll go see log file as soon as possible, thank you.
For the 3rd problem i try to eplain
if i receive an email with a link.. example http://www.directadmin.com and i click on this link in my browser the url that try to load is http://http://www.directadmin.com ... i think that webmail put a "http://" automatically.. and this cause that problem.. any idea?
thank you for ur attention.
Sincerely
No Problem, SeLLeRoNe. I'm sure your english is much better than my italian :) .
I don't know why the problem occurs with webmail and links. Do you use webmail (uebimiau) or squirrelmail? I just checked with a plaintext email with webmail, and it worked properly for me.
I just don't know then because it appears to work properly for me.
