Proftpd not starting after reboot
hpman28
Hi.
I installed a few updates, but didnt touched proftpd (1.3.0)
I did a reboot and the proftpd procces isn't starting.
After trying in ssh to run it, i get:
 - IPv4 getaddrinfo '' error: hostname nor servname provided, or not known
 - warning: unable to determine IP address of ''
 - error: no valid servers configured
 - Fatal: error processing configuration file '/etc/proftpd.conf'
I read here that it's because wrong hostnames in /etc/hosts.
It's a new server, and 1 of the lines in /etc/hosts are linking to a domain that is working on the old server.
this is the /etc/hosts file:
::1                     localhost localhost.my.domain
127.0.0.1               localhost localhost.my.domain
80.179.xxx.xxx          server.xxxxx.co.il
the xxx are something real... :rolleyes:
I need to transfer backups by ftp from the old server to the new one, so i need ftp somehow... Can i just add a command that proftpd will ignore errors in /etc/hosts?
Do you have a hostname? Is it served by DNS? If not, it needs to be set up in your /etc/hosts file.
I got a hostname, but until the server is not fully installed, the hostname is redirecting to another ip by dns.
I also get a directadmin message
This is e-mail notification to warn you that your hostname is setup improperly on your system.
Should i contact the guy that installed the server in the farm?
Cant i just remove the last line from /etc/hosts untill the server is working?
Solved...
I just ran hostname.sh with the ip.
How can i add that command to startup scripts?
It's freebsd 6, the startup dir is /etc/rc.d
Can u give my a small script that uses hostname.sh? Im not so linux user...
