Proftpd problem
csorbamedia
I hope someone can help me out!
Everything is working fine except after installing Directadmin on Centos 6.2 64 bit.
But proftpd is not working 100%.
When I try to login over ftp with a created ftp account
in directadmin it does not show me the files within the directory.
But when debug proftpd is on I see in the terminal that I'm (with my ip adress) logged in to the right folder home/user/domains/vhost domain/public_html. Does someone know how I can fix this. Maybe It's an rights issue?
Thanks in advanced.
Stephan Csorba
Try to disable firewall temporary on your server and see if the issue exits. If the things the same, try to switch from passive to active mode of connection or versa-virsa.
