Pure-ftpd init script and SSL issue
Richard G
Maastricht
Issue 1 (init script).
I just installed another new server and by accident I checkend the init script of pure-ftpd and compared them to other servers.
In the pureftpd init script on 2 older servers in the second OPTIONS= line I see:
HIGH:MEDIUM:+TLSv1:!SSLv2:!SSLv3"
On the 1 newer server and the one I installed today this line looks like this:
-S:HIGH:MEDIUM:+TLSv1:!SSLv2:!SSLv3"
Is the -S: needed in the beginning? And if yes, why is this not updated on the older servers?
Issue 2 (SSL issue).
When you restart pureftpd in the logfile you will see this:
(?@?) [DEBUG] Couldn't load the DH parameters file /etc/ssl/private/pure-ftpd-dhparams.pem
This wasn't there before and we do not have an /etc/ssl/private directory.
But we can make an /etc/ssl/private directory and according what I've read on the cpanel forums, this can fix this notice:
openssl dhparam -out /etc/ssl/private/pure-ftpd-dhparams.pem 2048
Question is, is this a good fix and if yes, can the creation of the directory and this fix be implemented by default in Directadmin?
Thank you Zeiter, but it does not really answer my questions:
I can add the -S: manually, that's no problem. But since !SSLv3 is already present, why put the -S: in front? It's overkill isn't it? And if not, why is it not adjusted on older servers?
Maybe zEitEr has an idea about this? Shoud I manually add it?
Any idea's on the SSL issue with pure-ftpd? Is that a good solution?
It was noticed that directadmin does not update init scripts, so it's up to you to update them to the latest version.
Thank you zEitEr, but in that case it would be nice if somehow you could get notice if and which init scripts were changed.
I believe at this time there is no such possibility?
Any clues on the SSL issue of pureftpd? Could this be fixed so on a DA pure-ftpd installation this will be done automatically?
