Quota/cron problem
perrera
Directamin doesnt show quotas correctly.
I haved check the /etc/cron.d/direcatmin file:
* * * * * root /usr/local/directadmin/dataskq
2 0-23/6 * * * root echo 'action=vacation&value=all' >> /usr/local/directadmin/data/task.queue;
#5 5 * * 0 root /sbin/quotaoff -a; /sbin/quotacheck -augm; /sbin/quotaon -a;
10 0 * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
20 4 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue
0 4 * * * root echo 'action=check&value=license' >> /usr/local/directadmin/data/task.queue
Its ok that the quota cron is commentd?
Sure it's okay ... if you don't want to run it. ;)
You need to know why it's commented out. Perhaps you're running a system which doesn't have quota support compiled into the kernel.
